I would like to get everything I need for a water cooling build. However this is my first attempt at water cooling and I am overwhelmed by the choices I need to make in equipment and sizes.
Could someone please help me. I have an idea of what I want, I just need help with all the appropriate compatible parts.
This is my system
Case - corsair 900D
MB - Asus crosshair VI Hero AM4
CPU - AMD 1800X Ryyzen
GPU - Asus RX 480 Strix
What I am looking for
Nice size radiator in white, 3 fan or 4 i believe i have enough room for anything
CPU block preferably with RGB and clear if available or just RGB if not
Resivoir - something like this but preferably with white accents  https://www.amazon.com/dp/B018IUI262/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=29P5Y145Q6DR5&coliid=I1QRU9I0X97BAA
Pump - dont know but a good pump variable i believe ( i have no idea)
Pipe - ridged pipe and necessary tools for heating and bending
Fittings - white preferably
Size - no idea, but i dont want to be constricted with size later in future or reduced water flow)
I just want a really good system that is future proof
Color of build is White and blue (vivid vinyl METALLIC BLUE DRY CARBON)
Please Help
Thank you
https://linustechtips.com/topic/748895-first-timer-help-with-parts/
For pump I recommend you to go for Laing DDC 3.2 or 3.25 with either bitspower or EK pump top, EK DDC pump heatsink and anti vibration mounts (included with the EK DDC pump heatsink). I recommend Bitspower or EK-WB Fittings.
CPU: Intel Core I7 7700K & Corsair H100i v2
Mobo: Asus Maximus IX Hero
RAM: 32 Gigs @ 3000Mhz, Corsair Dominator Platinum
GPU: Asus Strix 1080 A8G
Storage: Samsung 840 EVO 500gb
PSU: Corsair HX750i
Case: Fractal Design Define S
Just now, pals0007 said:
Will pcpartpicker help with with the appropriate tube sizes, fitting sizes IO/ID
You can go watch/study JayzTwoCents' Youtube channel. He is the king of custom watercooling (singularity Computers being the best at Modding+Custom Watercooling). He explains everything quite well. He has made videos specifically for fitting sizes, pumps, etc.
PSU: Corsair HX750i
