Help me please
Solved by iggybo,
1 minute ago, Dylan Davies said:I have a GTX 970 G1 Gaming Edition and AMD A10 6800k Black Edition and I'm wondering if either of these motherboards will be compatible with both
https://www.asus.com/Motherboards/F2A85V_PRO/specifications/
https://www.asus.com/us/Motherboards/M5A97_R20/
The second one won't work because of the wrong socket, but the first one should be ok.
Your CPU socket is AMD FM2, as long as you look out for that you should be fine. Graphics cards need a PCI Slot and enough power, that's it.
