Hey guys, I'm building a new system for gaming and was wondering if a gtx 1070 will pair well with an i5-7600k? I'm only going to be gaming so my question is: will the i5 be enough or should I ge the i7? I'll be gaming at 1080p 60 hz btw, Possibly 144 hz in the future.
https://linustechtips.com/topic/748321-need-cpu-advice-for-new-build/
More than enough i'd say.
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
6 minutes ago, FiveNine said:
If you have the option and it doesn't break the bank why not go i7. i5 should be sufficient though
Would I even use it to the full potential while gaming? Thats all I'm concerned about. I don't want to spend an extra 100 if its not going to matter for gaming (sice that'll be the most demanding thing I do with the system)
Wait for ryzen 5. Not sure why nobody else mentioned it, but there's very little on Ryzen 5 pricing. I'd guess you'd be able to get i5 level performance for cheaper. 7 was a dissapointment for many, but who knows, maybe Ryzen 5 will kick ass.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
Don't buy the unlocked i5, 4c/4t has its days counted, get the locked i7 7700 for the same price, you will get longer future proof, better performance in both multi-threaded applications and GAMES since the whole purpose of DX12 and Vulkan is to have games benefiting of more threads, even on skylake the tendency was already rising:
yes the locked 6700 still beating a highly overclocked 6600k, and keep in mind that b250 motherboards are the half the price the z270 ones while the stock cooler (provided that you don't mind its noise) is sufficient making the costs the same if not even better for the i7.
Personal Desktop":
Luna, the temporary Desktop:
Very interesting! I might just go for a i7-7770 since it can boost to 4.2 ghz. How about b150 motherboards?
They will work only if their BIOS are updated, which is never a guarantee, if they aren't you can only update them if you have a Skylake CPU at hand, in my case it was no issue as I originally had a 6700 (which I sold) so I could update my h110m BIOS before installing the 7700.
Personal Desktop":
