Hi, I've been thinking about building a new computer, but my knowledge is very limited!
"Used template from somewhere else"
  • Budget: 4.5k CAN$
  • More specific use (what games, what programs): OBS, WoW, BF, Any new game in ultra
  • Planned time until purchase: now-3months
  • Do you need an Operating System?: Yes if a good deal
  • Do you have any specific preferred components?: GTX 1080 (TI?), some kind of SSD (400Go+)
  • Do you need a sound or wireless card?: sound card
  • Do you want stock cooling or do you plan on overclocking?: Give me some advice here please
  • Do you need a monitor? mouse? keyboard?: Could use some advice for a good 144hz monitor with a good quality/money ratio
  • Zip code/location? (Shipping costs): Canada H1Y 3G6
  • What are your preferences in case style? (lights, flashy, dull, etc): Blue light, easy to maintain inside
  • Are you planning to use multiple monitors? 3
  • Are you looking for upgrade-ability? Yes
  • Do you have any preferred brands? Intel, NVIDIA
  • Can you reuse any components from an older build? Not really
  • Is there anything else you think we should know? I'm the kind of dude that do many things at the same time. I hate if something is slow. I often watch stream while playing games (stream + game must be smooth). I also usually never close my computer.
Thanks a lot for your help!
https://linustechtips.com/topic/748319-need-a-desktop-pc-built/
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($458.61 @ Vuugo)
CPU Cooler: NZXT Kraken X62 Liquid CPU Cooler  ($189.89 @ Newegg Canada)
Motherboard: Asus STRIX Z270-E GAMING ATX LGA1151 Motherboard  ($239.99 @ NCIX)
Memory: G.Skill Ripjaws V Series 32GB (4 x 8GB) DDR4-3200 Memory  ($264.99 @ Newegg Canada)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($223.98 @ DirectCanada)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($112.00 @ Vuugo)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($124.29 @ DirectCanada)
Power Supply: EVGA SuperNOVA G3 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($186.88 @ DirectCanada)
Monitor: Dell S2716DG 27.0" 2560x1440 144Hz Monitor  ($779.99 @ PC Canada)
Other: GTX 1080 Ti ($950.00)
Other: GTX 1080 Ti (in SLI) ($950.00)
Total: $4480.62
Generated by PCPartPicker 2017-03-06 11:33 EST-0500
Drop that second 1080 Ti if you don't feel needed. Price were approximate for them because at launch it supposed to be 699 USD which is around~930 CAD
https://linustechtips.com/topic/748319-need-a-desktop-pc-built/#findComment-9475558
kk give me a minute.
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/748319-need-a-desktop-pc-built/#findComment-9475564
1 minute ago, deXxterlab97 said:
<SNIP>
I would drop the second 1080ti, get a second samsung evo for raid0, and then add in 2 side monitors.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/748319-need-a-desktop-pc-built/#findComment-9475570
Total: $4480.62
Keep in mind my knowledge is very limited, but would the CPU be fine to record high quality, stream 1080 and play in ultra what ever game I'm playing?
https://linustechtips.com/topic/748319-need-a-desktop-pc-built/#findComment-9475610
This may be better for streaming, its the same as Dexxterlab's but with a 6 core CPU.
CPU: Intel Core i7-6850K 3.6GHz 6-Core Processor  ($765.00 @ Vuugo)
Motherboard: MSI X99A GAMING PRO CARBON ATX LGA2011-3 Motherboard  ($430.33 @ DirectCanada)
Total: $4251.33
Generated by PCPartPicker 2017-03-06 11:50 EST-0500
https://linustechtips.com/topic/748319-need-a-desktop-pc-built/#findComment-9475647
What about OC?  @deXxterlab97 (quoting so you see it)
Total: $4251.33
What about the compatibility check? Also, does raid0 really make that big of a difference even with ssd?
https://linustechtips.com/topic/748319-need-a-desktop-pc-built/#findComment-9475916
For gaming not much. I suppose you can do Raid
X62 will keep the temps low while overclocking
index.php?ct=articles&action=file&id=27149&admin=0a8fcaad6b03da6a6895d1ada2e171002a287bc1
index.php?ct=articles&action=file&id=27158&admin=0a8fcaad6b03da6a6895d1ada2e171002a287bc1
https://linustechtips.com/topic/748319-need-a-desktop-pc-built/#findComment-9475926
3 hours ago, ecnerwall said:
Any idea when gtx 1080 ti should be available in canada?
Release is supposed to be today. I would expect availability by the end of the month.
This is a bit of a flashy build. Lots of power for gaming. No need for a sound card in modern gaming systems. The motherboard provides generally excellent sound.
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($449.98 @ DirectCanada)
Motherboard: Asus STRIX Z270-E GAMING ATX LGA1151 Motherboard  ($253.80 @ shopRBC)
Memory: G.Skill TridentZ RGB 16GB (2 x 8GB) DDR4-3200 Memory  ($179.99 @ Memory Express)
Video Card: Placeholder for GTX 1080 Ti ($1000.00)
Storage: Samsung 960 Evo 500GB M.2-2280 Solid State Drive  ($336.00 @ shopRBC)
Storage: Western Digital Blue 3TB 3.5" 5400RPM Internal Hard Drive  ($113.00 @ Vuugo)
Case: Corsair Crystal 460X RGB ATX Mid Tower Case  ($166.27 @ DirectCanada)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($129.98 @ DirectCanada)
Monitor: Asus PG279Q ROG Swift 27.0" 2560x1440 165Hz Monitor  ($998.00 @ Vuugo)
Total: $3816.91
Generated by PCPartPicker 2017-03-06 16:23 EST-0500
https://linustechtips.com/topic/748319-need-a-desktop-pc-built/#findComment-9477278
Since you mentioned OS for a good deal, you can get a legit, legal copy of Windows 10 pro off of kinguin.net for about $35 (not sure what that is in CAD).
Midnight Rig - CPU: i7-7700K / Cooler: Corsair h100i V2 / Motherboard: AsRock Z270 Taichi / RAM: G.Skill TridentZ 3200Mhz / GPU: EVGA GTX 1070 FTW2 / SSD: Crucial MX300 525GB / HDD: Seagate Barracuda 2TB 7200rpm / PSU: EVGA Supernova B2 750W
https://linustechtips.com/topic/748319-need-a-desktop-pc-built/#findComment-9478417
