1 minute ago, LyricalRain018 said:
I want to get the corsair 100r case. But i cant decide whether to choose a one with side panel, or one with noise dampening material. What should i get?
BTW, is the seasonic s12ii 620w psu a good one?
PSU is good
I'd get none side panel unless you have something to show off
I'd go with silent unless you're planning to display the PC out in the open where plenty of people will see it, and even then I'd only go with the side panel if the internals are worth showing off.
I personally like side windows on builds I do water cooling in so you can monitor and watch for leaks and hopefully catch them before they become problematic and destroy your system. If you have air, get silent as it will help dampen the noise created by your CPU cooler depending on which one you get.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
