Power cut, my PC is most probably damaged.
Rob.S
I had a powercut while playing CS:GO.
Then it lagged a bit then all the lights and my PC went out.
It comes back later, so I boot my PC. Then it goes again.
Skip to when I am in Windows, and CS:GO suddenly takes 1 min to get to the homescreen, and works incredibly slow. All the stuff you see happen in the console, it's really slow. Usually took 10 seconds to get to homescreen.
Kingston HyperX SSD 480GB
I have scheduled a chkdsk for startup...
If my SSD damaged? I also used the "Check for errors" from the Tools Tab in Hard Drive properties (for both of my hard drives), no errors found.
I've only seen this happen for [CS:CO Installer](https://github.com/TheDoctor0/CSCOInstaller/releases/tag/1.43) as well.
Most other apps seem fine.
EDIT: FULL SPECS
CPU = i7 5820K @ 3.3GHz, Stock
GPU = 980Ti SLI
PSU = Corsair RM1000 (1000W, 80+ Gold)
Motherboard = Asus X99A
CPU Cooler = Corsair H100i
SSD = Kingston HyperX 480GB, CS:GO and Steam Installed here
HDD = Generic Toshiba Hard Drive, 2TB, 7200RPM, sometimes loud, mostly normal noise and normal speeds
FAQ
1. Is the 'homescreen' th steam homescreen?
2. You should check your SDD for any errors or bad 'sectors' (don't really know if they call them that on an SDD)
3. Is all of your RAM and the like registering in BIOS and Windows?
4. Is your PC making some kind of beeping noise when it is turned on?
5. Is your PC making any weird noise that you didn't hear before?
6. Is it only CS: GO or are any other programs or tasks affected? If it's only CS: GO, it is possible that some files have been corrupted, and when going to the 'homescreen' it just tries to open them again and again, until it times out and eventually gives you what it has. Has any sound or visual effects dissapeared from the 'homescreen'?
Answer:
1. CSGO Home screen / Main menu
2. How
3. Will check
4. Only the normal single beep that the self check is successful, is normal.
5. No, haven't had enough time to judge but is fine
6. Most likely corrupted files, was playing the game when the power went off. **But I answered that on my post!** I can't tell if it is trying to open them again and again, but it just does what it usually does, but extreme slowly. Anyway I'll just re install it, hopefully it didn't nuke my other games.
ALL ABOVE PASTED FROM REDDIT.
> How can I recover from this and find out which files were corrupted or lost
All help is very much appreciated
Excuse the terrible formatting.
EDIT: Corruption confirmed. There's no way CSGO isn't corrupted. Now just need help to recover from this
If you feel there is something wrong with you counter strike alone then just full delete it through steam and reinstall it ?
Personal Desktop":
Luna, the temporary Desktop:
Yes but the fear is other things may be corrupted, how do I check if they are, how do I check for damage to the whole hard drive, how do I check what has been corrupted and I didn't only have one app open, and some other things have been corrupted that were used at the time!!! There's must be more! My PC is in a mess dude and I need to find out what is corrupted! Will I just live with corrupted files and apps all the time? Opening every single app would take years!!! HELP
If it's your files that are corrupted i suggest resseting whole pc.
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
EDIT: FULL SPECS
GPU = 980Ti SLI
FAQ
Answer:
2. How
3. Will check
Sue your power company for a new pc;)
Shit. FML I did not fucking need this shit. Thanks for the reply though. Jesus Christ just started a hobby on it. FUUUUUUUUUCK
How can I find out what is corrupted and what isn't.
Use crystal disk info SMART tool to check for anything wrong with your drives.
Download a program, like what ninjake said. But i suggest just reset the pc
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
