Just now, COUPER MILLAR said:
You don't have a psu, also for $30 you could get 16gb ram which is always nice.
wat... $30 for 16GB of RAM? Where the hell do you shop? 8GBs of RAM is $50 in USD... And that's for the cheap ass ugly kits.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/747987-mini-itx-build/#findComment-9471542
My bad I meant $30 more as in total price of $120
Edit. 16 gb of ecc ddr3 can be had for $30 on ebay though. Not applicable in this case, but still possible
Edited by COUPER MILLAR
https://linustechtips.com/topic/747987-mini-itx-build/#findComment-9471560
Just now, mpsparrow said:
$30 more then the 1 x 8GB stick the dude had in his build.
Which isn't true. https://ca.pcpartpicker.com/product/dwhj4D/corsair-memory-cmk8gx4m1a2666c16 is what OP should get. Cheapest 16GB kit after that is $124
https://linustechtips.com/topic/747987-mini-itx-build/#findComment-9471561
Yeah... someone didn't do their research.... tisk tisk @COUPER MILLAR
https://linustechtips.com/topic/747987-mini-itx-build/#findComment-9471567
The case listed in the op does not include a psu. The one that does is  Fractal Design Node 202 HTPC Case w/450W Power Supply.
You might consider a slightly different build. One that includes a 1TB ssd. Beside neither drive in the OP has a very good reputation.
I couldn't find a Cryorig C7 priced on ca.pcpartpicker. The Noctua is a good alternative.
Cut the gpu down to the 3GB memory version to fit in the budget. Given the usage, it should not be an issue.
Windows 10 OEM license does not allow for DIY builds. Hence the inclusion of a full version.
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  ($259.75 @ shopRBC)
CPU Cooler: Noctua NH-L9i 33.8 CFM CPU Cooler  ($48.99 @ Newegg Canada)
Motherboard: ASRock H110M-ITX/ac Mini ITX LGA1151 Motherboard  ($94.00 @ Vuugo)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2666 Memory  ($69.99 @ Amazon Canada)
Storage: Crucial MX300 1.1TB 2.5" Solid State Drive  ($348.98 @ DirectCanada)
Video Card: EVGA GeForce GTX 1060 3GB 3GB SC GAMING Video Card  ($249.98 @ DirectCanada)
Case: Fractal Design Node 202 HTPC Case w/450W Power Supply  ($179.99 @ Newegg Canada)
Operating System: Microsoft Windows 10 Home Full - USB 32/64-bit  ($128.98 @ DirectCanada)
Total: $1380.66
Generated by PCPartPicker 2017-03-06 21:11 EST-0500
https://linustechtips.com/topic/747987-mini-itx-build/#findComment-9478732
On 05/03/2017 at 10:33 PM, prostrike33 said:
Looking for advice on this build I'm working on. My max budget is about $1300 - $1400
BUILD: https://ca.pcpartpicker.com/list/FnzRRG
https://pcpartpicker.com/list/ this is 200 USD over, but it will wreck everything you throw at it, my friend has this exact build and it works great for him. One note though, you need thr Hue+ in order to control the RGBs on the cooler and the fans
CPU Intel Core-I5 6600K OC to 4.4GHz MOBO MSI Z170A Gaming Pro Carbon RAM 16GB Kingston HyperX Savage DDR4-2400MHz GPU Gigabyte GTX 1060 G1 Gaming 6GB
Cooler Cooler Master Hyper212 Evo PSU Corsair RM650x 650W Boot drive Kingston v300 120GB SSD Storage WD Blue 1TB 7200rpm HDD Case Corsair Carbide Spec-03
Extra NZXT Hue+ LED light controller + 2xNZXT Aer 120mm RGB fans
https://linustechtips.com/topic/747987-mini-itx-build/#findComment-9479657
