so everytime i shut down my computer, and start it back up the next morning, i have to restart because cam software does noet recognize my kraken x62, after the restart it works just fine. any fix for this?
also, razer synapse is working like its supposed to, but when i open chroma configurator for my blackwidow chroma X it says image failed to load and i cant customize anyting? anybody else had/ is having this issue?
Current Build:
CPU: Intel Core i7-7700K at 4.8Ghz CPU Cooler: NZXT Kraken X62 AIO Motherboard: gigabyte Z270X ultra gaming
Memory: Trident Z rgb 16gb 3000Mhz
Storage: Samsung 250GB SSD Storage2: sandisk ultra II 960gb SSD Video Card: Asus GeForce GTX 1080 O8G STRIX
Case: Phanteks ECLIPSE P400
Power Supply: Corsair RM650X Fans: 2x 120mm NZXT Aer rgb LEDcontroller: NZXT Hue+ LEDstrip: cablemod hybrid-LED/UV 60Cm
peripherals:
Keyboard: Razer Blackwidow X Chroma Gamepad: Razer Tartarus Mouse: Razer Mamba TE 2015 Chroma Headphones: Logitech G533 Wireless
Operating System: Microsoft Windows 10 Pro OEM Monitor1: AOC Q2577PWQ 2560X1440 OC'ed to 75 Hz Monitor2: LG 25UM57-P 25.0" 2560x1080 OC'ed to 75Hz
PCpartpicker list: https://pcpartpicker.com/list/Qt76xY
My laptop: https://www.amazon.com/Acer-VN7-571G-50VG-Notebook-Computer-i5-5200U/dp/B01CL50JV6
Quote:
If you really want it, go get it.
https://linustechtips.com/topic/747829-problems-with-cam-software-and-razer-synapse/
btw i know razer synapse is the worst software for any peripheral ever.
Current Build:
peripherals:
