Posted March 5, 2017 From what I've been reading, AMD Ryzen has a problem at 1080p, but not at higher resolutions. My question is this: Will this problem extend, or be exacerbated by gaming a 5760x1080 in triple monitor surround? Ketchup is better than mustard. GUI is better than Command Line Interface. Dubs are better than subs Link to comment https://linustechtips.com/topic/747788-zen-and-ultrawide/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 5, 2017 1 minute ago, Trik'Stari said: From what I've been reading, AMD Ryzen has a problem at 1080p, but not at higher resolutions. My question is this: Will this problem extend, or be exacerbated by gaming a 5760x1080 in triple monitor surround? That still count's as 1080P if I am sure. Link to comment https://linustechtips.com/topic/747788-zen-and-ultrawide/#findComment-9469194 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 5, 2017 I'm not quite positive of what those issues were. But part of me is assuming that they were for on-board graphics. So I would assume that you are in the clear. Link to comment https://linustechtips.com/topic/747788-zen-and-ultrawide/#findComment-9469202 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 5, 2017 Author 2 hours ago, Factory OC said: That still count's as 1080P if I am sure. Technically yes, but it is still a bigger workload, although I have no idea if this could possibly be an issue. I'm just curious as to what the community thinks or if anyone has tried it yet. Even more so considering the next step in my upgrade process is a new CPU, mobo, and ram. 2 hours ago, GlassBomb said: I'm not quite positive of what those issues were. But part of me is assuming that they were for on-board graphics. So I would assume that you are in the clear. Hmmmm. Still so tempted to just go with Kaby Lake. Especially with AMD having the ram problem. I don't need to drop this much money on something that doesn't work (i.e. it gets here, and won't post because of the ram speed) Ketchup is better than mustard. GUI is better than Command Line Interface. Dubs are better than subs Link to comment https://linustechtips.com/topic/747788-zen-and-ultrawide/#findComment-9469208 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 5, 2017 Just now, Trik'Stari said: Hmmmm. Still so tempted to just go with Kaby Lake. Especially with AMD having the ram problem. I don't need to drop this much money on something that doesn't work (i.e. it gets here, and won't post because of the ram speed) Looking into the whole ordeal as we speak. PCPer seems to have some information about it. Link to comment https://linustechtips.com/topic/747788-zen-and-ultrawide/#findComment-9469221 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 5, 2017 1 minute ago, Trik'Stari said: Hmmmm. Still so tempted to just go with Kaby Lake. Especially with AMD having the ram problem. I don't need to drop this much money on something that doesn't work (i.e. it gets here, and won't post because of the ram speed) Ryzen has a little bugs here and there, and Kaby lake processors got a little cheaper, so you can buy Kaby lake if you would like. Ryzen will be good in a couple of months, but not now. Link to comment https://linustechtips.com/topic/747788-zen-and-ultrawide/#findComment-9469228 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 5, 2017 14 minutes ago, Factory OC said: That still count's as 1080P if I am sure. Mega ultra wide 1080p lol 1080p usually reads as the normal 1920x1080p, 5000x1080p is a loooot more of a resolution, you could call it that I guess but it definitely isn't in the same "level" OP will be fine using the 1800x, the higher the resolution the less of a bottleneck the CPU will be, when going 4k benchmarks did show the ryzen 7 closed the gap more. If you need to push as much frames as possible because you want to play CsGO or such in 1080p then yah you will have to go Kaby Lake but if you just want casual high resolution game, the AMD offering is good, just make sure your graphics card is up for the task. Personal Desktop": CPU: Intel Core i7 10700K @5ghz |~| Cooling: bq! Dark Rock Pro 4 |~| MOBO: Gigabyte Z490UD ATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: RX 6900XT Sapphire Nitro+ |~| PSU: Corsair TX650M 80Plus Gold |~| Boot: SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro. Luna, the temporary Desktop: CPU: AMD R9 7950XT |~| Cooling: bq! Dark Rock 4 Pro |~| MOBO: Gigabyte Aorus Master |~| RAM: 32G Kingston HyperX |~| GPU: AMD Radeon RX 7900XTX (Reference) |~| PSU: Corsair HX1000 80+ Platinum |~| Windows Boot Drive: 2x 512GB (1TB total) Plextor SATA SSD (RAID0 volume) |~| Linux Boot Drive: 500GB Kingston A2000 |~| Storage: 4TB WD Black HDD |~| Case: Cooler Master Silencio S600 |~| Display 1 (leftmost): Eizo (unknown model) 1920x1080 IPS @ 60Hz|~| Display 2 (center): BenQ ZOWIE XL2540 1920x1080 TN @ 240Hz |~| Display 3 (rightmost): Wacom Cintiq Pro 24 3840x2160 IPS @ 60Hz 10-bit |~| OS: Windows 10 Pro (games / art) + Linux (distro: NixOS; programming and daily driver) Link to comment https://linustechtips.com/topic/747788-zen-and-ultrawide/#findComment-9469241 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 5, 2017 5 minutes ago, Princess Cadence said: Mega ultra wide 1080p lol 1080p usually reads as the normal 1920x1080p, 5000x1080p is a loooot more of a resolution, you could call it that I guess but it definitely isn't in the same "level" OP will be fine using the 1800x, the higher the resolution the less of a bottleneck the CPU will be, when going 4k benchmarks did show the ryzen 7 closed the gap more. If you need to push as much frames as possible because you want to play CsGO or such in 1080p then yah you will have to go Kaby Lake but if you just want casual high resolution game, the AMD offering is good, just make sure your graphics card is up for the task. Sure, thanks for the info. Link to comment https://linustechtips.com/topic/747788-zen-and-ultrawide/#findComment-9469266 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 5, 2017 12 minutes ago, Trik'Stari said: Especially with AMD having the ram problem. reviewers running benchmarks at 2933 or close to 3000hz. thats fast enough for almost everything. no performance gain can be seen even if ram runs faster than that. the real issue was low ipc and lack of optimization for zen architecture- which is understandable ..the hardware is new . if u only game 7700 no question. but if u also render or something then ryzen because ryzen will come very close in gaming (that resolution will also help) Link to comment https://linustechtips.com/topic/747788-zen-and-ultrawide/#findComment-9469293 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
