Firstly, what type of water cooling setup are you going for?
Custom or AIO.
If custom then, hardpipe/tubing.
Generally you would first start by noting the 120mm/140mm mounting points on the case and begin from there.
Here is the mounting location for the enthoo pro.(Attached)
https://linustechtips.com/topic/747681-how-to-water-cool/#findComment-9468350
What case you got?
Nvm, its right in the op. Its still early and I just woke up :P
Main Rig:-
Server:-
https://linustechtips.com/topic/747681-how-to-water-cool/#findComment-9468351
Custom or AIO.
Im going for custom
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/747681-how-to-water-cool/#findComment-9468354
Just now, xDylanio said:
Im going for custom
I would highly suggest going for an AIO solution for watercooling if you are new to this. However if you feel adventurous enough then go ahead. I currently have limited knowledge of custom loops so you might wanna ask someone else on that :D.
https://linustechtips.com/topic/747681-how-to-water-cool/#findComment-9468356
I've had a corsair h100i gtx since i got my pc. But I'm feeling like doing something new. So instead of upgrading components, I'm upgrading the cooling.
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/747681-how-to-water-cool/#findComment-9468369
