one sec....
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
we are fast
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://au.pcpartpicker.com/list/9Kjghq
The power supply is quite low quality, but not a bomb (if you can, i would highly recommend upgrading it to something better)
other than that, it's pretty good (albeit slightly above budget)
Laptop:
Just now, ms-DOS said:
oh and btw it needs to run minesweeper at the max settings 4k 9000000000000000000000000fps
shit dude.. what monitor you got that can run at that framerate?
Laptop:
Just now, SCHISCHKA said:
Ms dos needs a new PC? Where have you been for the last 20 years?
hiding in widows 95 and 97
1 minute ago, GDRRiley said:
I'd recommend he get a cheaper case, cheaper SSD (120GB) but save enough to go with a quad core.
but it's totally his choice
also, you need to mention that the board might not be compatible out of the box. unless he has a friend with a skylake CPU, he shouldn't order a 100 series chipset.
Laptop:
the bios has been out for 9 months now it is fine
