I have a Corsair h100i v2 (Soon to arrive) and I am going to be replacing the stocks fans
Are these basically the same (Apart from one has PWM Support) I want it to be silent as possible
PWM - http://www.maplin.co.uk/p/corsair-air-series-sp120-pwm-high-performance-edition-120mm-fan-twin-pack-a12nq
Other- http://www.maplin.co.uk/p/corsair-air-series-sp120-quiet-edition-120mm-fan-twin-pack-a11nq
Or should I go the oppisite and go for an air flow fan?
http://www.maplin.co.uk/p/corsair-air-series-af120-quiet-edition-120mm-fan-twin-pack-n85qq
https://linustechtips.com/topic/747448-what-fans/
I recommend you use Noctua NF-F12's.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/747448-what-fans/#findComment-9465792
44 minutes ago, sigge300 said:
they are basicly the same, just that the quiet edition does not have pwm control and run slower out of the box. on a radiator do not go for airflow fan as they lack static preasure to push/drag air through the radiator.
Whice should I buy then?
https://linustechtips.com/topic/747448-what-fans/#findComment-9466018
For most people and at stock speeds, Corsair fans will be fine, just not really silent. If you want extra fans from Corsair, stick with the SP series of fans, they are optimized for high pressure applications like radiators.
Another good option would be the Silverstone AP series or Noctua NF-F12.
In either case I would let them run at 7V. This gives you a nice tradeoff between performance and acoustics.
If you want to do some overclocking, of course, running them silent won't be such a good idea.
Another one of my favorites is the Noctua NF-P12 (also available as PWM), running at full speed because it is quieter than most pressure optimized fans at 12V and also pretty close in terms of performance. They have been my go to fans for various applications for years now. I have one in my NAS still doing fine after almost 10 years of service.
https://linustechtips.com/topic/747448-what-fans/#findComment-9466179
if you want looks and silence go with be corsair air series sp fans, I have put a link below.
https://www.pccasegear.com/products/23805/corsair-air-series-sp120-quiet-edition-pwm-twin-pack/
but if you want high performance that be it at a higher price go with Noctua nf f12 fans.
https://www.pccasegear.com/products/27866/noctua-nf-f12-industrial-ppc-120mm-3000rpm-pwm-fan/
sorry no RGB this time, hope this helped.
https://linustechtips.com/topic/747448-what-fans/#findComment-9471547
