2 minutes ago, Truthful Cake said:
I need some opinions of the Dell Inspiron 15 7000 series laptop's. I am considering buying one, while Linus' review was nice and all, it just didn't give me all the detail I needed.
Any comments or suggestions would be much appreciated.
What detail would you like?
https://linustechtips.com/topic/747401-opinions-required/#findComment-9465302
5 minutes ago, Truthful Cake said:
Basically, would it be a good choice for that price range or is there something better out there.
well for that cheap you cant get a better gaming laptop. now if you dont want a gaming laptop or if you can spend more you can find better options but that's all dependent on you.
https://linustechtips.com/topic/747401-opinions-required/#findComment-9465320
6 minutes ago, Truthful Cake said:
General use, no extremely high end titles, and some basic rendering work such as CAD and CAM, although heavy game modding will be a part of its use.
4 minutes ago, Truthful Cake said:
I say extremely high end titles but it may be used for games such as doom, fallout 4 and Dying Light.
Then it could be a nice addition for the price. I would go for it if I were you. It really doesn't get too hot for a laptop. And it really isn't over the top with appearance. You should keep a mouse round. The SSD can help, but if you need more than 256GB, then you should get a higher tier version, or just put in a HDD. The full USB ports are a nice edition to laptops today. A TN display is really not that bad, but if you want good color reproduction, plug in another monitor. Overall, not bad for the price.
https://linustechtips.com/topic/747401-opinions-required/#findComment-9465362
I would highly advise at least the 1050ti. Check out the the y520, vx15, n850hk1.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/747401-opinions-required/#findComment-9466128
Yeah the Inspiron 7000 (7567, 1050/1050Ti) model has a horrible-quality TN panel, so I generally don't recommend it (unless you're into LCD swapping)
The N850HK1 is a great option for this price. GTX 1050 Ti and a great display for $899.
1080p model, that is. Be aware that the 4K model uses a PenTile not-true-4K display, and if you wanted 4K then I would go with the Inspiron 7567 (4K model) since it uses a true 4K display.
https://linustechtips.com/topic/747401-opinions-required/#findComment-9471703
