Wireless repeater?
Go to solution Solved by 79wjd,
You can connect via ethernet to a secondary router in between acting as a range extender/repeater, but you will still have wifi at some point in that connection.
But NEVER use wireless extenders (which is what you're describing). They're trash.
You have three options:
-Wifi card if you have a strong enough signal.
-Run an ethernet wire half-way to a router (and use that router as an access point) and use a wifi card in your PC.
-Run an ethernet all the way from the router to your pc.
-Try a powerline ethernet adapter.
I am currently in the process of building a PC and I am contemplating whether or not I should get a wireless network card (since I already have a wired-only one). The reason I am thinking of getting a wireless network card is because if I want to use the wired one I will have to run an ethernet cable from the top floor of my house to the basement and there are doors in the way. Not only that, if I used a wired connection; I will pretty much get double the network speed. I have a couple spare routers lying around and I was thinking of using one of them as a wireless repeater (or something like that), where they intercept the signal from upstairs and allow me to connect to the internet from the 'wireless repeater' via an ethernet cable. Is this possible? Any suggestions?
https://linustechtips.com/topic/747361-wireless-repeater/
Possible? yes. Good? not in the slightest.
M1 MacBook Air 256/8 | iPhone 13 pro
https://linustechtips.com/topic/747361-wireless-repeater/#findComment-9464895
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/747361-wireless-repeater/#findComment-9464903
17 minutes ago, PacketAtlas said:
Depending on how old your house is you could use a Powerline Network Adapter.
That really depends on the circuitry, even in a newish house. My house is relatively new but PowerLine SUCKS here.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/747361-wireless-repeater/#findComment-9465006
