This video is  in german, so most of you won't understand what they are talking about but if you look at the cpu utilization in some games compared to the 5960X and the 6900k you will see Ryzen gets a bit less utilized in those scenarios, so the claim of AMD that it is just a optimisation problem seems now even more valid.
i5 6500 @3.2Ghz, Zotac GTX 1080 Ti Mini, 16GB DDR4 @2400Mhz, 240GB SSD, 1TB HDD, Corsair Vengance 650W, Asus Z170 Pro Gaming, Thermaltake Versa U21, Hyper 103
AOC Agon AG271UG 27" 4k G-Sync, G933, G502, G801
https://linustechtips.com/topic/747346-ryzen-not-fully-utilized/
This makes literally 0 sense
https://linustechtips.com/topic/747346-ryzen-not-fully-utilized/#findComment-9464746
Didn't know AMD even went out and claimed that, but we've all known that Zen isn't very well optimised for, nor could it be. It's different enough to both older AMD microarchitectures and contemporary Intel ones that it won't do well with code optimised for either of those, and it's new enough for no game developers having had serious time with it yet.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
https://linustechtips.com/topic/747346-ryzen-not-fully-utilized/#findComment-9464747
If you watched the most recent WAN show, i think that the point linus made about the whole amd response the 1080p benchmarks on the 1800x is quite valid, amd hasn't had a new cpu out for years so its not surprising that at the moment games run better on intels platform and in the next few years hopefully as there is better support for the ryzen cpu's we should hopefully be able to see the difference be almost non existent.
https://linustechtips.com/topic/747346-ryzen-not-fully-utilized/#findComment-9464749
It does make some sense. It wouldn't if the comparison were made with a quad core or a hexa core. If you compare the utilization of two octa core processors, and one is utilized less which results in worse performance, you may ask why it is utilized less. It would seem logical to say "Ryzen is worse for gaming because at the same or higher level of utilization by game engine the performance is inferior", wouldn't it? Not: because it is not utilized as much as the competitor. Then of course I don't really know much about these things - I only point out what seems more logical to me, a layman.
https://linustechtips.com/topic/747346-ryzen-not-fully-utilized/#findComment-9465457
This would be valid if the comparison is between 2 same CPUs from same line-up and architecture
https://linustechtips.com/topic/747346-ryzen-not-fully-utilized/#findComment-9468370
