2 minutes ago, Over9000Dude said:
anyone know about a pci expansion card with 4 or more usb 3.1 ports?
Why do you need USB 3.1? What's wrong with just USB 3.0?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/747035-4-usb-31-pci-card/#findComment-9461624
1 minute ago, Over9000Dude said:
tha speeds
But why?
SPECS:
https://linustechtips.com/topic/747035-4-usb-31-pci-card/#findComment-9461654
3 minutes ago, CUDA_Cores said:
That would require a PCIe x4 Gen 3 USB expansion card as Each USB 3.1 port would require one PCIe lane. There are two port PCIe cards but I don't think such a thing exists.
i can use a 16x slot if i need to, i have about 14 lanes to spare
https://linustechtips.com/topic/747035-4-usb-31-pci-card/#findComment-9461657
Just now, CUDA_Cores said:
dude, its a f*ckin waste of money to have ports you don't use. Spend that money on something more meaningful like a new CPU or GPU.
im going to build an all new pc
amd oc 1700.
gtx 1080.
carbide air 240.
250gb 960evo. 2tb barracuda.
gigabyte gaming 3 ga-aB350m.
32gb vengeance led ram.
rm750x
https://linustechtips.com/topic/747035-4-usb-31-pci-card/#findComment-9461683
Why do you need any more as that board comes with 2 USB 3.1 Gen 2 type A ports.
Also all the cards I've seen either have one type A and one type C, two type C, two type A or two type A and one type C
As @CUDA_Cores has stated it's a waste of money since there are already the ports you want on the motherboard, and you can easily multiply them by buying a hub which is likely to be cheaper then getting another card.
https://linustechtips.com/topic/747035-4-usb-31-pci-card/#findComment-9461722
