Hello guys,
So, this friend of mine asked me to find a gaming pc to replace the old Mac he uses which is owned by his parents. He has a maximum budget of 800 euros (that's why the pc part picker is/should be in german/deutsch) and I've already picked the parts. I believe he has a monitor or we'll figure that part out later. What I am concerned about is cables. I still have a SATA cable so that's no problem, what I am concerned about is the gpu cable. Or rather, every cable. I've never bought a full build before so don't have experience with the psu. Does the psu come with all the cables? Does the psu come with extra cables for the gpu? And for the hdd? Can you guys recommend any changes? (800 euros max, set to Germany/Deutschland) this is the list: https://de.pcpartpicker.com/list/XN3y9W Have fun cringing over the extreme prices and my bad choices! (there are so many cpus... Help)
Oh yeah, we live in The Netherlands but the Belgium region is extremely expensive...
Thanks in advance!!!
Windows 10 | GTX 970 | AMD Ryzen Threadripper 3960x | 128GB Ripjaws V
https://linustechtips.com/topic/745685-help-with-first-build-cables/
You don't need extra cables, typically the motherboard comes with 2 Sata-Cables (1 with straight-straight connectors, 1 straight-rectangular) and the psu does come with all cables it is able to handle, nothing to worry about you will be fine. Though keep in mind that PCPP does not list a price for your particular chosen psu, so you will pay more eventually. Getting a 6600k with a B150 is also not a good option as you can't overclock it on that chipset. I suggest dipping the k and get a 6500.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (€210.79 @ Mindfactory)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€33.08 @ Mindfactory)
Motherboard: Asus B150M-K Micro ATX LGA1151 Motherboard  (€72.00 @ Amazon Deutschland)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  (€72.36 @ Mindfactory)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€49.31 @ Amazon Deutschland)
Video Card: XFX Radeon RX 480 8GB XXX OC  Video Card  (€242.18 @ Mindfactory)
Case: Thermaltake Versa N21 ATX Mid Tower Case  (€43.95 @ Amazon Deutschland)
Power Supply: SeaSonic 450W 80+ Gold Certified Semi-Modular ATX Power Supply  (€73.84 @ Mindfactory)
Total: €797.51
Generated by PCPartPicker 2017-03-01 15:47 CET+0100
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
Yes, PSU Comes with all the cables you need.
Your CPU is unlocked - thus the "k" on the end, but B150 Chipset won't allow you to overclock it. Go for x99 or z170 on the motherboard.
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
14 minutes ago, Pokemoneuro said:
Hello guys,
The parts come with the cables you need. As for build:
PCPartPicker part list: https://de.pcpartpicker.com/list/tJpB9W
Price breakdown by merchant: https://de.pcpartpicker.com/list/tJpB9W/by_merchant/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  (€185.83 @ Mindfactory)
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  (€52.43 @ Mindfactory)
Memory: Team Elite 8GB (1 x 8GB) DDR4-2133 Memory  (€54.74 @ Amazon Deutschland)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  (€49.99 @ Amazon Deutschland)
Video Card: XFX Radeon RX 480 8GB RS Video Card  (€249.93 @ Mindfactory)
Case: Cooler Master N200 MicroATX Mini Tower Case  (€45.84 @ Mindfactory)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (€82.13 @ Mindfactory)
Total: €770.20
Generated by PCPartPicker 2017-03-01 15:51 CET+0100
Total: €797.51
Thank you for your reply. I changed the case to something else because he wants a black and red scheme. And yes, I do look at the clearance height of that cooler. Another question: does the cpu come with thermal paste applied? Or thermal paste at all?
Yes, the 212 Evo comes with a small tube of thermal paste.
Most coolers come with thermal past as @WMGroomAK already stated, though I forgot to mention and also forgot while creating this parts list that the 6500 already comes with a stock heatsink, so you could save yourself 30€ and don't get the aftermarket cooler
- Ryzen Build -
2x Dell UP2516D
Yeah, I knew that. But I thought I might as well keep it since you obviously (I thought) but it there for a reason xD. Maybe I can use that extra money for another motherboard. Since... Well... Any other recommendations? I have this now https://de.pcpartpicker.com/list/4mmCKZ. I kinda wanna replace the motherboard with something better and cheaper.. No problem if Pcpartpicker doesn't have the seller, it's probably still available. Check the German Amazon other websites like Tweakers.net. Maybe just give some options and I'll look.
EDIT: I went to look and found this one https://tweakers.net/pricewatch/496253/msi-h110m-gaming.html (sorry for dutch site but it also shows merchants!) Afuture has it pretty cheap so I think that this is gonna be the final motherboard for this build! The IO is pretty respectable... Not great, but respectable..
Recommending Skylake when Kaby lake chips are available @ the same price point?
The tech community never seizes to amaze me.
I7-7700k@5.1ghz + 1080ti @ 2050mhz + 32gbs Ram + 2TB SSD = CSGO
i7-6700k@4.9ghz + 980ti @ 1501mhz + 16gbs Ram + 1 TB SSD = Backup
i7-3770k@4.8ghz + 680 4gb + 32gbs Ram + 500gb SSD = Retired/Office work
looks solid in its final form.
@PCMasterDebater: yeah you can go with kaby, but 1.) improvement = zero over skylake, maybe 1 or 2 % and 2.) always a thing with budget boards and bios updates, could possible lead to some headaches, so why not go with leaving the possible trouble behind and just get skylake, it's not a bad chip. COnclusion: you can go with kaby, but skylake will offer you no real disadvantages.
heck i even build a haswell system for a friend though skylake was already out: What i've won with that: i5 for 30-40 bucks less and no performance loss because it was only paired with a GTX 950 (though it should be noted that there would have been a performance gain with a higher performance gpu and skylake i5 in opposite what we have here). I don't think you will be able to tell any difference between this system with skylake vs. this system with the 7500
- Ryzen Build -
2x Dell UP2516D
There is literally a 6 dollar price difference between a i5-6500@3.2ghz and the i5-7500@ 3.8ghz and a $10 difference between a h110 and a h270.
600mhz for $16...
This is dollars and that's great and all... But how are the price differences in Europe? (Not the UK... I don't live there and I only really care about Dutch or German resellers..)
6 minutes ago, Pokemoneuro said:
This is dollars and that's great and all... But how are the price differences in Europe? (Not the UK... I don't live there and only really care about Dutch or German resellers..)
EDIT:  I looked it up. What can I say I became curious   :P
17 euro difference from the 6500 to the 7500.
and a 3 euro difference from a h170 to a h270. the h270 is cheaper.
For 14 euros, you can gain 600mhz and have hardware from 2017!
Yeah... the tech community never seizes to amaze me.
12 minutes ago, PCMasterDebater said:
I lack the time to find out for you. Jump on PCpartpicker, Newegg, or any german website to find out yourself.
Alright, I found out that the i5-7500 is actually like 5 euros cheaper than the i5-6500!
But... There are no motherboards that actually fit in the budget if I choose that one. With these options there is nothing fitting under 800. And he is already squeezing out more money for a monitor... So he'll just have to settle with a generation older.
4 minutes ago, PCMasterDebater said:
Owh... I searched for that thing you said.. h270... Others are way cheaper than that! This is the build now: https://de.pcpartpicker.com/list/j2C8m8/ I guess that this is the final version of it! Unless it's possible to squeeze an SSD in there... 800 euros is juuuuuust not enough... Oh well, he'll be able to put an SSD in it later on
