power supply What happen if i buy a 1000w Power Supply if i need less?
Solved by Sakkura,
41 minutes ago, IsraChido said:I will use only the 300 W, or i will use the 300 W and the company of electricity will charge me the 1000W, when im only ussing 300W.
When your components are drawing 300W, the power supply will draw a little more AC power from the wall, maybe 375W, and then generate the required 300W of DC power for the components. The rest is lost in the conversion process and becomes heat inside the power supply.
A more efficient power supply loses less power this way, and that also means it has less heat to get rid of. So higher efficiency power supplies are typically less noisy.
26 minutes ago, deXxterlab97 said:there is no white certification
The plain 80+ rating (below 80+ bronze) uses the white color.
