Built my own PC, ran perfectly first 2 days. After that it started running a lot worse. I think the problem is my PC isn't using the correct graphics card, I think it's using the built in one instead but I don't know how to switch it. When I right click desktop and click AMD Radeon settings it just says Radeon settings are currently not available.
I don't know shit but i'm here anyways.
https://linustechtips.com/topic/744395-pc-not-running-as-should/
1 minute ago, ChaseKayzer said:
How do I find all my drivers I need to re install? I don't have a disk drive so I can't download them manually.
wait what??? do you not have storage at all? just download them onto the ssd or boot drive
https://linustechtips.com/topic/744395-pc-not-running-as-should/#findComment-9431341
What I meant was I do not have a CD drive to install with a in real life CD to install the drivers that came with the PC. Instead I have to search them but I don't know which ones I need or what to download after I remove all my drivers.
https://linustechtips.com/topic/744395-pc-not-running-as-should/#findComment-9431359
You download them online from AMD's website.
https://linustechtips.com/topic/744395-pc-not-running-as-should/#findComment-9431378
