corsiar 600q http://www.corsair.com/en-us/carbide-series-quiet-600q-inverse-atx-full-tower-case
cpu 7700k kaby lake or x370 1700 amd ryzen https://www.newegg.com/Product/Product.aspx?Item=N82E16819117726   https://www.newegg.com/Product/Product.aspx?Item=N82E16819113430&cm_re=AMD_Ryzen-_-19-113-430-_-Product
noctua cooler https://www.newegg.com/Product/Product.aspx?Item=9SIAADY44C5830&ignorebbr=1
gigabyte   motherboard z270 https://www.newegg.com/Product/Product.aspx?item=N82E16813128962#   https://www.newegg.com/Product/Product.aspx?Item=N82E16813128992
noctuca fans 5  https://www.newegg.com/Product/Product.aspx?Item=N82E16835608044 https://www.newegg.com/Product/Product.aspx?Item=9SIA9PV3Y62838
ram 64 https://www.newegg.com/Product/Product.aspx?Item=N82E16820233891&cm_re=ram_ddr4_64_gb-_-20-233-891-_-Product
m.2 Samsung 960 1 tb https://www.newegg.com/Product/Product.aspx?Item=9SIA4S854Z0974&cm_re=samsung_960-_-20-147-597-_-Product
sound card asus   https://www.amazon.com/Xonar-Essence-STX-II-7-1/dp/B00JF6RO7C/ref=sr_1_1?s=pc&ie=UTF8&qid=1488144948&sr=1-1&keywords=ASUS+Xonar+Essence+STX+II+7.1
fan control https://www.nzxt.com/products/sentry-3
ssd 4  https://www.newegg.com/Product/Product.aspx?Item=N82E16820156149 https://www.newegg.com/Product/Product.aspx?Item=N82E16820147566
1080 ti nvidia or 1080 300 power supply
memory card reader https://www.nzxt.com/products/aperture-m
power supply http://www.bequiet.com/en/powersupply/760 http://www.bequiet.com/en/powersupply/759
webcam https://www.logitech.com/en-us/product/brio
keyboard http://www.corsair.com/en-us/strafe-rgb-mechanical-gaming-keyboard-cherry-mx-red
gaming mouse http://gaming.corsair.com/en-us/corsair-gaming-sabre-laser-rgb-gaming-mouse
https://linustechtips.com/topic/744348-power-supply-advice/
Just now, RandomGuy13 said:
Be Quiet is a decent enough brand, should be fine.
seasonic, corsair, evga, sliverstone are some other good brands. I would not buy any sketchy brands as they have a habit of blowing up motherboards.
600 is it ok or 700
https://linustechtips.com/topic/744348-power-supply-advice/#findComment-9430716
53 minutes ago, RandomGuy13 said:
You would be fine with 600w but that leaves you with no room to expand in the future. I would go with the 700w supply. its probably not a whole lot more expensive.
A single GTX 1070 and a 6950X might use 350W if you really tried...
EDIT: OP said 1080ti, a 600W would still allow for plenty of overclocking with headroom.
1 hour ago, patriciadiaz1919 said:
A Seasonic G-series, or EVGA GQ/G2/G3 would be much better for the money if you want a quiet unit.
https://linustechtips.com/topic/744348-power-supply-advice/#findComment-9431022
2 hours ago, patriciadiaz1919 said:
600 is it ok or 700
No, for _ONE_ Card you need 400 and might want to go for 500W.
600W is more for dual GPU setups, as is 700W and total bogus for a Single CPU/GPU graphics card setup.
The Pure Power L10 looks like an awesome unit, at least in the lower wattage ranges. Efficiency is high, it has independently regulated rails and decent components, nothing wrong with it.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/744348-power-supply-advice/#findComment-9431605
500W is more than enough, even 400W is plenty. Modern rigs don't consume that much power that one would want a 600W for a single Card setup.
And the Pure Power 10 is rather good, voltage regulation on +12V could be better but Ripplesupression in 230VAC areas is just awesome and probably better than Seasonic G-Series. From the ones you mentioned only EVGA G2 and G3 are really better, but only in Semi Fanless mode. The fan in the Pure Power 10 (I think be quiet mentions that it should be a Rifle Bearing one) is also rather good...
https://linustechtips.com/topic/744348-power-supply-advice/#findComment-9431623
I'd not personally use a 400W PSU with a "1080 ti" (assuming that the increase in power consumption from Maxwell to Pascal remains consistent across all Nvidia GPUs) seeing as a 980ti + Core i7 system could feasibly consume that much power with overclocking.
https://linustechtips.com/topic/744348-power-supply-advice/#findComment-9431779
