Help Programming Media Controls To Keyboard?
My friend gave me his Ducky Zero, I upgraded from a G710 which had media controls. I like the feel of the Ducky, but it does not have any media controls. It does have volume controls, and a function key. There is a program called "AutoHotkey" which programs keyboard bindings. The issue is that I don't have a clue on how to program for such a thing, because the only time I've programmed something was for school, and i failed the project. If anyone has experience, I would like to know how I can program the FN key to give secondary functions to the volume control keys, those secondary options being: play/pause, forward and back for media controls. I know there are plently of tutorials online, but i don't have enough time to do a crash course on this specific function. Thanks in advance.
pictures of key placement for reference:
Space Journal #1: So Apparently i  was dropped on the moon like i'm a mars rover, in a matter of hours i have found the transformers on the dark side of the moon. Turns out its not that dark since dem robots are filled with lights, i waved hi to the Russians on the space station, turns out all those stories about space finding humans instead of the other way around is true(soviet Russia joke). They threw me some Heineken beer and I've been sitting staring at the people of this forum and earth since.
https://linustechtips.com/topic/742878-help-programming-media-controls-to-keyboard/
There's a program called SharpKeys that allows you to use the registry to map buttons to media controls. It's open source and available on Codeplex: https://sharpkeys.codeplex.com/
I currently use it to map useless buttons like insert, end and pause to play/pause, previous and next. No programming is needed to map the keys.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
thank you so much for the reply. I'll be sure to check it out.
