Hi, so my Fast Track (fasttrack.sys if memory serves) has been causing IRQL_NOT_LESS_OR_EQUAL BSOD's on my Gigabyte 775 build with Windows 10.
I know the drivers aren't supposed to support windows 10 but the BSOD's have been happening since windows 8 on this particular machine.
I have heard people complaining about Gigabyte motherboards with M-Audio products a fair bit so my question is this.
Is there a fix for the BSOD's, if no, is the issue likely to persist on a different PC, if yes, does that mean it's time for me to replace it?
I know it's old but it's served me well over the years and it will be sad to see it go. There is a Native Instruments Komplete Audio 6 for sale near me for like $80 AUD so if need be I'll probably grab that.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/742829-bsod-m-audio-fast-trackwindows-10/
Yes
@rice guru
