I am Considering getting a Fiber switch for my personal network... Main Pc, Server and my other Pc on the other side of the house as a start. Anyone know anything about the IBM 2109-F16 TotalStorage 16 port 4B Fiber switch, or the IBM Totalstorage 2005-16B in terms of how friendly the ios is and if either have a need for proprietary IBM 4GB fiber nics to connect properly to said PCs or other switches with a fiber interface? I come from using cisco equipment and a little bit of HPs Procurve switch ios if that helps.
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
https://linustechtips.com/topic/741822-ibm-switches/
This is a SAN switch meant to be used with fibre channel adapters and provide NFS/iSCSI like storage to servers through a dedicated storage network. it's not meant to form a LAN like an Ethernet switch (which could also use fiber connections). Are you certain that's what you really want?
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9404057
I already saturate my 1GB ports on my current switch very often and upgrading to 4 or 8GB fiber will be a huge boost to transfer speeds between my equipment. As long as I can add ip addresses to the nics, and drivers for said nics that work in windows 7 and server 2012 R2. As 10GB is currently very expensive, infiniband is just plain janky and unreliable to get working with anything but proprietary equipment and networks, and 1GB isn't enough for me, 4GB or 8GB fiber is the best and seemingly only option right now. I don't necessarily need so many ports on the switches but at the current prices i'm finding them its a pretty good deal compared to new hardware.
RAINBOWS!!!
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9406987
That's fine but you just have to understand that this hardware is not meant to connect things together in a LAN. It is for storage only. That means only for connecting PC's to a "NAS" in a dedicated network that runs parallel to a LAN
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9407354
@Gaub is correct and to add onto that FC switches communicated over the Fibre Channel protocol which is not the same as IP.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9407862
That is one issue I have. I'm not sure if these (or similar switches like ones from Qlogic) support FC/IP or iFCP in a way I could relatively easily learn and implement it ( I currently know very little about how to implement it properly)
On 2/22/2017 at 10:24 PM, Windspeed36 said:
Have you looked into the total costs of doing this?
  • Switch
  • SFP modules
  • Fibre cable
  • FC cards
    • Driver support for said cards
So far I can get the switch for anywhere between $20 and $90CAD, FC cards with SPF modules for between $20 and $40CAD each depending on how many ports I want, and the cables i currently need for about $60CAD total.
So right now total cost would estimated be about $250-$300 CAD depending on how our dollar is doing. Far less then a 10GB switch and the modules for it.
I did look into a 1GB switch with Link aggregation but with the large single file transfers I do It won't do much as it only really helps when transferring multiple large files at the same time.
Currently I easily max out the theoretical throughput of 116/123MB/s  of a 1GB interface so thats the whole reasonfor me to upgrade. I just don't want to spend hundreds or thousands (which I really can't afford) on a single piece of super expensive hardware mostly unnecessary (at this point) when I can get the whole used setup for way less.
RAINBOWS!!!
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9416191
Alternatively If you can point me in the direction of some cheap 10GB cards and a 2-3 port 10GB ethernet switch... :P Don't think there's such a thing but doesn't hurt to ask!
RAINBOWS!!!
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9416573
If all the equipment is close to each other, 15m, you could just full mesh them using something like Mellanox ConnectX-2/3 cards. That's as low cost as you'll get but scalability is terrible lol.
As everyone else has said Fibre Channel is Fibre Channel and Ethernet is Ethernet, they are totally different. FC isn't for transferring files between computers like Ethernet/IP is used for so if that is what you are looking for look elsewhere.
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9417301
14 hours ago, SimssmiS said:
There is a series about 10Gb/s Network over on youtube by iTechStorm. Hes building a custom 10Gb/s switch maybe that helps you or is just plain interesting.
(cant post the link here you will find it i´m sure)
Just watched it! And I think i'm sold (also super cool!!) :) Considering I don't need DHCP right now for my private network I think it would work perfect for my use case for the next while. Now if I could get my old lga 771 dual xeon to work.... I could use that as a base with its2 gb network ports, 2 pcie x4 and 2 x16 slots (also has 2 pci slots but i won't need those) :P hmmmm...
RAINBOWS!!!
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9421604
good to hear i helped :) i´m going to try 10Gb/s my self but only peer to peer for now
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9422517
Ubiquiti has some 10Gb switches that are reasonably cheap,  Both SFP and RJ45 inputs.
Ok for a home network, but not really enterprise grade https://www.ubnt.com/edgemax/edgeswitch-16-xg/
Have one at work, but pulling it out tomorrow as swapping in a HP procurve 10Gb IRF cluster.
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9422616
My question though is what is affordable/cheap in this case xD
RAINBOWS!!!
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9425215
17 minutes ago, leadeater said:
About $600 excluding cables/SFP+ modules.
OUCH!!!!!
post-25905-0-66739400-1377957174.gifAAEAAQAAAAAAAAZ8AAAAJDQ3MjIyOTA0LWY2MjUtNDY0ZS1hNWNlLTE3NDFiNzgzZDY3Ng.jpg
RAINBOWS!!!
https://linustechtips.com/topic/741822-ibm-switches/#findComment-9425693
