Hey so I recently watched the $150 gaming pc video with 8 cores and so on. So i decided to try it out and orderd up some stuff what i currently have is a intel s5000sl motherboard with daul x5450 cpu at 3ghz and 16gb of ddr2 ram at 667mhz with a roswill 700 watt power supply brand new and 2 dynatron cpu coolers with a temorary old pc 500 gb hdd. I want to know whats the newest os i can put on here liek could it run windows 10? Can I put windows 7 on it for now and upgrade later since 7 is cheap. Also I cant for the life of me figure out how to turn it on since i dont have a case or the interface that comes with one such as the power button haha. Any help would be appreciated sorry for the bad grammer/spelling typed in a hurry. picture before i hooked up everything
https://linustechtips.com/topic/741695-need-help-with-recent-build/
to turn it on you would need to bridge the pins for now, in future i reccomend buying a button from radioshack and wiring up that button to the pins
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
wait is that a rackmount case?
