So, just got a x62 kraken as my h110i pump died, i never really fiddled with the pump on the h110 only the fans.
If you change it to performance mode, the rpm of the pump increases. Wouldn't that be worse for cooling as the water spends less time going through the radiator?
https://linustechtips.com/topic/741604-aio-pump-mode/
With larger/faster pumps (4800 RPM and higher flow) in a custom water loops, there is a point of diminishing return in increasing flow rate, but too much flow is never an issue.  AIO pumps wouldn't exactly fall into the excessive category by any means.
In the end, it all balances out and the only thing that really impacts performance negatively is too little flow and even at that, it was have to be under flowing by a lot to even notice.
https://linustechtips.com/topic/741604-aio-pump-mode/#findComment-9400946
No, it is performance mode after all xD
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/741604-aio-pump-mode/#findComment-9400949
3 minutes ago, JamesHewitt said:
So would you say go for silent then if it's not gonna really effect it too much?
AFAIK, silent mode slows down the fans as well... Which does affect performance.
https://linustechtips.com/topic/741604-aio-pump-mode/#findComment-9401072
1 minute ago, JamesHewitt said:
Fans and pump have separate controls though
Then use silent mode for the pump, it shouldn't affect performance (Much)
https://linustechtips.com/topic/741604-aio-pump-mode/#findComment-9401343
