4.9 or 5-ish.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
1 minute ago, Remonix said:
Really? That doesn't sound very stable
It's what most people are cranking out. i wouldn't use it as an everyday clock, but if you're looking for sheer numbers, that's what you can expect. -ish.
It's the SillyCon lotto and all, though it seems with Kaby Lake production quality has gone way up.
System specs:
2 minutes ago, Remonix said:
So what would be a day-to-day overclock?
something that keeps you in the low 70's under load...
System specs:
Okay i have Gigabyte 2AC8 Motherboard with a AMD 8350 FX and a EVGA 1070 GTX Superclocked i have tried to overclock. on CB with no Overclock OpenGL score 77.96 CPU 477 CB. if it move power or clock this stat will tank. anybody know what might be going on? or do i need a better MB for overclocking?
if at first you don't break it you must have followed the directions
this doesn't belong here. make a troubleshooting thread of your own please.
System specs:
1 hour ago, Remonix said:
yeah how many Ghz would that be?
depends on what your specific setup yields you. probably somewhere in the 4.8 or 4.7 territory. It all comes down to the voltage required.
System specs:
