1 minute ago, Eguun said:
1. 24inch tn vs 27inch ips
2. i usually play csgo and i think 27 inch is better for aiming small heads.
3. if money is not issue should i go for 27 inch 100%
4. both will be 144hz or higher but tn will gsync
Its just preference if money is no issue, but bigger is better D:
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/740119-24inch-vs-27inch/#findComment-9385436
Until you get to around 40" ;)
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/740119-24inch-vs-27inch/#findComment-9385458
Which exact Models?
1. TN is faster, IPS looks more beautiful. IPS will have the IPS-Lottery from the AUO Panel, so you might get ugly Backlightbleeding, Glowing, etc. That's a valid reason for many, to send it back, and get teh TN one.
Otherwise: Tn will be a tad bit faster. shouldn't be able to notice it.
Also, it depends on resolution. If it's 1080p, you should not go for 27" at ALL. everything will look so huge and un-sharp and pixely.... ugh.
1080p on 22-24", or 1440p from 24" above is a goods sweetspot. Most will prefer 1440p on 27"; as it won't need any scaling, if text might appear a tad too small for you.
For my Desk, 27" was a bit too big. i'm happy with my 24" now at 1440p.
2. Nope, smaller one is better, because you have all the stuff going on in a smaller area. Smaller Area can stay betterin your Focus view. Big screen might be great for other games, but usually, smaller gives you a beter view to everything.
Other than that, which can be preference... How far do you sit away from it? 1 meter, i would not get 24".
50cm, i would not get 27".
3. No. Because like said above, 1440p / 27" IPS Panels with 144 Hz+ have quality issues. The Question is if you can live with them better, than with the disadvantages of TN. I send the AUO Model with IPS and G_Sync back
4. for only CS:GO, doesn't matter. you won't use G-Sync on CS:GO.
For other games, G-Sync is pretty good.
Again, which monitors are we talking about, and how much do they cost?
You can not say which one is better at all, just from the size of it. You need to know the specific model.
https://linustechtips.com/topic/740119-24inch-vs-27inch/#findComment-9385495
