Hello, sorry for my bad english.
I have a 1TB hdd wdc 2,5". It has 2 partitions inside.
yesterday, suddenly the hdd is unreadable.
The partition 1 (D) can accessed but very slow data, and Partition 2 (E) is totally unaccesable. There's no errors when i tried to click partition 2, but it kept loading, made explorer hang.
I tried with easeus data recover, it kept loading never end.
using chk dsk command, only show this
help :(
a GeForce GTX series 970 user.
https://linustechtips.com/topic/739866-help-strange-hdd-unreadable/
  • 2 weeks later...
Your drive most likely has developed bad sectors and will need to be imaged on data recovery hardware. I suggest you contact a data recovery company in your area. A software program like EaseUS is not going to help you, this is a hardware problem.
There are some DIY options, but I don't suggest them if the data is important.
Data recovery specialist. Contact me for data recovery in Cape Town or any hard drive related information.
