1 minute ago, OMKAR PATADE said:
I have i7 6700k
I do 2d/3d cad ,solidwork ,maya and rendering stuff
I want to buy moboard pls suggest
My budget is 150 usd $
MB dont give performance just pick one that has the connectors and headers u need ie theres not point gettin a MB with crossfire if you are running nivida cards
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/739780-help-me-pls/#findComment-9382237
Most motherboards support both crossfire and sli rather than a specific one, so that's not the best example :P
https://linustechtips.com/topic/739780-help-me-pls/#findComment-9382247
I don't think there is a motherboard that is not either old or only supports sli an doen't crossfire
My life
https://linustechtips.com/topic/739780-help-me-pls/#findComment-9382374
or an MSI Z170-a, either way if you got a unlocked CPU yo should invest in an z170-a And about brand, it comes down to your personal preference of aesthetics and support in your country for the brand.
CPU: Intel Core i5-6600K, Motherboard: MSI Z170A GAMING M5, RAM: G.Skill DDR4 2 x 8GB GPU: MSI GTX 1070 Gaming X, Case: Cooler Master MasterCase 5
Storage: WD Blue 1TB, Samsund 850 EVO 250 GB, PSU: Corsair RM 750X, Display(s): BenQ BL2710PT: Cooling: Thermalright True Spirit 140 Power
Mouse: Gamdias DEMETER II- 3200DPI Gaming Mouse, Operating System: Windows 8.1
https://linustechtips.com/topic/739780-help-me-pls/#findComment-9382601
