Hi, Everybody
I am going too (build) a Media Centre PC I already have some parts.
Specs:
I5 3470 (Already own)
GTX650 (Already own)
HDD 1 TB WD Green (Already own)
Fractal Core 1000 USB 3.0
Gigiabyte GA-H61M-D2H-USB3
300n PCI wireless card
Hyper TX3 EVO or Stock intel cooler
It has too be as quite as possible. Is this fine or is something else better (about same budget)
My english is not so good sorry about this :)
  CPU:   Intel I5 3570K @ 4,6 GHZ   -- MOBO: Asrock Z77-Extreme4 -- GPU: EVGA GTX 770 2GB -- PSU:Corsair TX750M -- R AM: 16 GB 1333 MHz -- HDD: 2x 2TB -- 1x 120 GB HyperX SSD -- AUDIO: Creative Audigy 2 -- CASE: Fractal Design R4
-- Actually Like Windows 8 --
https://linustechtips.com/topic/73892-home-media-centre-pc/
Just run the on board graphics and save the GPU for something else - the fans on the GPU add to the noise and Intel HD is perfectly fine for playing videos at 1080p.
MAXIMUS VII HERO | i7 4770K w/ H100i | 2x8GB 1600MHz | GALAX GTX 970 x2
250GB SSD boot | 250GB x2, 1TB SSD storage | Corsair 400C | Corsair RM550
https://linustechtips.com/topic/73892-home-media-centre-pc/#findComment-1012396
It seems all you need is the psu and some ram.
Other than that, you'll have a pretty beast media pc.
https://linustechtips.com/topic/73892-home-media-centre-pc/#findComment-1012442
But its just laying around and the fan is pretty silent see pic
https://linustechtips.com/topic/73892-home-media-centre-pc/#findComment-1012445
Sorry have CX500 watt psu
And 8gb 1333 Mhz ram
https://linustechtips.com/topic/73892-home-media-centre-pc/#findComment-1012449
Well you're set. If the system is loud, think of replacing the fans. Otherwise, keep it as is.
https://linustechtips.com/topic/73892-home-media-centre-pc/#findComment-1012453
Yes it has a big fan, but that's still excess noise. Try it in, and if you find it's whirring up too much then take it out. Like I said - it's not needed in a media PC. If you want silence you need less fans, not more.
https://linustechtips.com/topic/73892-home-media-centre-pc/#findComment-1012508
Yeah, don't waste money on a CPU cooler, the stock one is so adequate for your build. Looks really nice though, I recently built in the Core 1000 - it's lovely.
This ^^^^
https://linustechtips.com/topic/73892-home-media-centre-pc/#findComment-1012509
