Help flashing BIOS.
Solved by RileyTheFox,
2 minutes ago, DewgSauce said:So i have a new build but i need to update the BIOS to a new version to use my processor. My problem is i have to get into the BIOS to update it so i can use my KABYLAKE processor. it's a brand new build, what can i do?
components:
i5 7600k
GAB150-HD3P
8gb RAM
120GB SSD
1TB hard drive
thanks for your help.
You will need a Skylake cpu
