3 minutes ago, RAM555789 said:
I'm looking for a joystick to play some flight simulators for around $30-$75, anyone have any ideas?
get this :
it has dual throttle too !
https://www.newegg.com/Product/Product.aspx?Item=N82E16826618026
@themctipers hapy now ?
https://linustechtips.com/topic/738532-best-joytick/#findComment-9369272
17 minutes ago, givingtnt said:
get this :
Its got a lot of bad reviews, do you personally own this stick or just look it up and saw it has dual throttle.
https://linustechtips.com/topic/738532-best-joytick/#findComment-9369371
no, I personally owned the x52 (wich broke) and currently have an x55 rhyno. wich is eh.
I used this stick for a few times, its not too bad. what kind of simulators do you play ? (fsx style or war thunder simulation style ?)
https://linustechtips.com/topic/738532-best-joytick/#findComment-9369416
FSX, War Thunder, Elite Dangerous, and when I build a new PC, DCS World
https://linustechtips.com/topic/738532-best-joytick/#findComment-9369439
yeah it will be good. you get a good vlue for the price.
https://linustechtips.com/topic/738532-best-joytick/#findComment-9369462
2 hours ago, givingtnt said:
get this :
I'm triggered
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/738532-best-joytick/#findComment-9370135
