Hi everyone,
I'm building a game PC and only need to buy the CPU, CPU cooler, Motherboard, GPU and PSU. Which do you advise me to buy? I can spend max 1000 euro on these components. I am going to use the pc for gaming (and rarely some photoshop work)
RAM: corsair vengeance lpx 16GB 3200MHz
HDD & SSD: WD 1TB & Samsung 960 EVO 512Mb (pci m.2 SSD)
Case: NZXT h440 RAZER edition
Thanks!
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/737655-help-with-components/
PSU anything TIER 1 to TIER 3 from this list
GPU, see if you can fit i5 and 1070 if not i5 an 480 or 1060 is fine
Cooler: Gamamxx 400 if you can, Hyper 212 is fine but only if you buy a K cpu
16GB is fine though 8 is ok for now
960 Evo is soooo expensive, get a Crucial SSD instead
If you go with K cpu so you can overclock you should get Z170 or Z270 motherboard
If not K then get H110 or B150 motherboard (or H210 or B250 if you go with 7th gen CPU)
https://linustechtips.com/topic/737655-help-with-components/#findComment-9359659
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor  (€281.18 @ Amazon Italia)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  (€129.99 @ Amazon Italia)
Motherboard: ASRock Z270 Pro4 ATX LGA1151 Motherboard  (€124.98 @ Amazon Italia)
Video Card: MSI GeForce GTX 1070 8GB Video Card  (€452.11 @ Amazon Italia)
Power Supply: Cooler Master GM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (€65.98 @ Amazon Italia)
Total: €1054.24
Generated by PCPartPicker 2017-02-13 21:41 CET+0100
https://linustechtips.com/topic/737655-help-with-components/#findComment-9359670
i5-7600k 212 cpu cooler a 650w psu and then a sli mb and a 1070 or 1080 if it fits the bugget the reason for the over kill psu and sli mb so u can go sli later on if u want to
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/737655-help-with-components/#findComment-9359690
Total: €1054.24
Italian price and netherlands price are different since Netherlands have way more options to choose from and he could maybe fit an i7 there
https://linustechtips.com/topic/737655-help-with-components/#findComment-9359691
yes, hold on
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  (€364.99 @ Amazon Deutschland)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  (€42.15 @ Amazon Deutschland)
Motherboard: ASRock Z270 Pro4 ATX LGA1151 Motherboard  (€122.05 @ Mindfactory)
Video Card: MSI GeForce GTX 1070 8GB Video Card  (€439.99 @ Amazon Deutschland)
Power Supply: Cooler Master GM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (€47.17 @ Mindfactory)
Total: €1016.35
Generated by PCPartPicker 2017-02-13 21:45 CET+0100
german prices - pcparticker doesn't support netherlands
https://linustechtips.com/topic/737655-help-with-components/#findComment-9359696
1 minute ago, gtx1060=value said:
yes, hold on
Total: €1016.35
I'd try for a CX450M as GM is Tier 4 as oppose to Corsair's. I am sure you can do that, drop to 212 Evo or M9i if needed
https://linustechtips.com/topic/737655-help-with-components/#findComment-9359704
https://uk.pcpartpicker.com/list/67C2TH
this can go sli in future if u wanted to
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/737655-help-with-components/#findComment-9359725
thats uk build, he lives on italia
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/737655-help-with-components/#findComment-9359799
 I live in the Netherlands :D
https://linustechtips.com/topic/737655-help-with-components/#findComment-9359855
its 1000euro on exchange rate
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/737655-help-with-components/#findComment-9359892
still
https://linustechtips.com/topic/737655-help-with-components/#findComment-9363602
