Will a i7 4770 make a big difference over a i5 6400 with a gtx 1060 6GB? or will the gpu be maxed out by both and show no gains? If i bought the i5 6400, i could squeeze an ssd into my budget, or some other £45 upgrade. The price delta is £45, with the i5 costing £120 and the i7 costing £165 (both are used, from Cex with warranty). The motherboard etc is around the same price. I would need a cooler for them both, but no overclocking would take place. this is the i7 build https://uk.pcpartpicker.com/list/vzMGHN and this is the i5 build (for some reason the i5 4430 costs the same. and the 4460 costs more) https://uk.pcpartpicker.com/list/BnHvm8
https://linustechtips.com/topic/737643-will-i-see-a-difference/
Depends on what you're doing, and if gaming, the game.
I'd just wait for Ryzen if you're thinking about upgrading anything.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359496
Gaming- BF1, Shadow of Mordor, Valve Games, Minecraft, Mirrors Edge /Catalyst, Portal 1/2, maybe GTA V and far cry primal soon (I play whatever i can find that looks good and i can afford). I am not upgrading, I'm planning a build.
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359509
1 minute ago, Abyssal Radon said:
An i5 wouldn't slow a 1060's performance. What I would recommend waiting for Ryzen to hit the market before you upgrade/buy hardware.
It was the other way around. Will a 1060s performance be better with an i7? in the games i listed above
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359512
Still, that doesn't change the fact you should wait and see what Ryzen is like.
As for how it performs, you can go to YouTube and there should be videos of each combination. Just see how the framerate plays out, and you'll have your answer.
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359525
An i7 will always fare better with games. Although an i5 with a better GPU, i.e. paired with a 1070 would ultimately give you a better experience.
I can't afford a gtx 1070 unless i buy a pentium g4560 or x4 845 (£40-65 cpus) and the motherboards have to be cheap too (so no i7 first gen)
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359535
i may or may not wait for ryzen. i can wait 3-4 more weeks max.
i cant find any using both the 1060 6gb and a 4770
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359555
4 minutes ago, Abyssal Radon said:
Well then I would say get a i7. Pair it with a 1060 for now, upgrade later.
that B85 board https://www.msi.com/Motherboard/B85M-G43.html#hero-overview says it can overclock, but since its b85, can it??? i am just wondering
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359581
If memory serves, the overclocking functionality on that (and many other H81, B85, H87 boards) is only for the Pentium G3258.
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359740
i7 will give u more frames but it will give u like 5 so i would the £45 in yr pocket and go for a pint :)
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359741
Even if the board can, the 4770 can't.
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359781
1 minute ago, Ethan Meskin said:
I'm 13, i'd rather buy games or an ssd
sucks for u
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9359917
This is how I think it works.  Some entry level boards have a form of overclocking that is built into the motherboard bios.  For MSI it's OCgenie.  I think it slightly changes the voltage or base clock to give you a 100mhz boost or something like that.  It's nowhere near the same thing as having a Z series board to change the k multiplier on a cpu.
As for the original question, I would definitely take the 4770 over the 6400 in most cases, but both cpus can handle a 1060 no problem.  Having the 6400 means you'll be on a newer platform and have a little more room to upgrade in the future if you want.
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9360159
1 minute ago, Biggerboot said:
This is how I think it works.  Some entry level boards have a form of overclocking that is built into the motherboard bios.  For MSI it's OCgenie.  It's not a really effective method of overclocking like adjusting the k-multiplier on a z series board.  I think it slightly changes the voltage or base clock to give you a 100mhz boost or something like that.
can the 4770 last me 5 years? if so ill keep it for that long and buy a new motherboard and cpu and ram
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9360170
It's subjective.  I would say it can, but it really depends on your needs and expectations.  Software requirements are always changing so sometimes it's hard to see that far ahead.  But given the history of CPUs as of 5 years ago, chances are you will be fine.
Case in point, sandy bridge i7s still does kind of ok today in AAA games, and it's a 6 year old cpu.  Haswell is now 2.5 years old.
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9360210
I think I'll go with that then. Thanks
https://linustechtips.com/topic/737643-will-i-see-a-difference/#findComment-9360248
