Automotive Sound Deadening for PC
m0k
has anyone ever considered using this in a PC? I know its heat insulating as well but with good case airflow it shouldnt be an issue right?
https://www.amazon.ca/16-36sqft-Insulation-Self-adhesive-Deadening-Automotive/dp/B01KAD24RI/ref=sr_1_3?s=automotive&ie=UTF8&qid=1487007856&sr=1-3&keywords=Sound+Proofing+Insulation
Feel free to leave other options for me (preferably under $30 CAD)
Photography / Finance / Gaming
might help if there's ticking, buzzing or coil whine bothering you, but you'll still have noise coming from where your fans are. But yeah, as long as you have good airflow you should be fine
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
I have used something similar.
It sure sticks well, but didn't have as much of an effect as I had hoped probably because most of my noise comes from HDDs which are mounted near air intakes which I don't want to block and they're tightly screwed to a metal chassis which transmits sounds well.
