HELP!!!
Go to solution Solved by aisle9,
55 minutes ago, Crimson Chin said:
It fell into the GPU while outside the case so its either lost and it doesnt matter as it was only the screw above the hdmi port or its in the heatsink
Take the GPU apart and find it. Leaving it in there could cause God knows what damage to the GPU, and it could damage the motherboard as well depending on where it is and where it ends up when the fans kick in.
take it back apart and remove the screw.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/737328-help/#findComment-9356111
Lol I'm sort of tuned to not let shit stay missing - I work on aircraft, tools, screws, bolts, rags, whatever they have to be found!
Think of the worse case scenario, your GPU dies, do you wanna buy a new one?
You move the whole tower around/upside down until it drops out, but if this GPU is air cooled, just take it out and source the screw before you switch it on
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/737328-help/#findComment-9356156
i hope it doesn't' scratch the pcb, that will damage the card, but depending on the damage it might work or kill it
don't worry it will ReLive Crimson Chin!
ha ha get it?
the Radeon Software Crimson ReLive Edition?
my comedic genius is wasted on you fools.....
2e3b2571d880b539359acc578ff2ea39be0af18f
why thank you random person!
****SORRY FOR MY ENGLISH IT'S REALLY TERRIBLE*****
Been married to my wife for 3 years now! Yay!
https://linustechtips.com/topic/737328-help/#findComment-9356157
It was a screw that was above the hdmi port and it was very small. I don't see it on the circuit board the only other place it could be is under the fans in the metal thing that looks like a radiator kinda. I don't know to much about computers but it looks like this card if it helps any.
Image result for 270x gfx
https://linustechtips.com/topic/737328-help/#findComment-9356188
18 minutes ago, stealth80 said:
Lol I'm sort of tuned to let shit stay missing - I work on aircraft, tools, screws, bolts, rags, whatever they have to be found!
I don't care too much about the gpu but if it bridges contacts will that ruin my computer or just the gpu. It's air cooled by the way
https://linustechtips.com/topic/737328-help/#findComment-9356214
as if I didn't say "to not let shit stay missing" .... :/
What GPU is it? Just take the GPU out and remove the screw? Sounds like you're trying to break it on purpose, there's safer ways of doing that
Ryzen Ram Guide
https://linustechtips.com/topic/737328-help/#findComment-9356220
it's a R9 270x. I took the circuit board off and the top cover I see no sign of it I don't think it was small enough to go anywhere else and I lost it while at my cousins house so i could have fallen out there. It only cost me $50 bucks from him and I have one currently I just want to know if it does bridge contacts will it ruin my entire computer or just the gpu.
https://linustechtips.com/topic/737328-help/#findComment-9356251
if it bridges I would just cause a GPU error I would think. They normally get stuck in the heatsink or drop down to the bottom of the PC, normally somewhere you cant access easily like down the side of the PSU!
Ryzen Ram Guide
https://linustechtips.com/topic/737328-help/#findComment-9356256
https://linustechtips.com/topic/737328-help/#findComment-9356264
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/737328-help/#findComment-9356408
