Under load, in this case, my gtx 980 TI windforce gets up to 80c with the top glass panel plus dust filter on it... Unfortunately you have to use the dust filter to have the top piece of glass on it. When I remove these two things however, the temps drop almost 4 degrees. Is there any way to fix this?
https://linustechtips.com/topic/737210-corsair-570x-gpu-temps/
Do you have intake fans?
https://linustechtips.com/topic/737210-corsair-570x-gpu-temps/#findComment-9358112
I have tried just about every configuration of fans. It comes with 3 intakes in the front, and I have 2 in the top and one in the back. I have tried intake on top as well as exhaust, but it doesn't seem to make a difference.
https://linustechtips.com/topic/737210-corsair-570x-gpu-temps/#findComment-9359889
