So I figured out the safety margin needed for my scissor lift design that the theater department wanted. What I did was use the bending formula with a 3D truss of a basic X lift. After more mental pain than taking an ACT 2 times in a row I got it done.
A smile goes much farther than the person it's meant for.
First impressions are important, it sets the stage for respect.
"If you don't know every word you don't know it!"- SGM McCray
https://linustechtips.com/topic/736740-hard-problems-are-hard/
Also that formula is   (Moment*surface area of a face) / moment of inertia about a neutral axis. Thats the long way of saying if it will snap or bend under the stress given to the object.
https://linustechtips.com/topic/736740-hard-problems-are-hard/#findComment-9349951
*Insert response here*
https://linustechtips.com/topic/736740-hard-problems-are-hard/#findComment-9349952
*Insert response to response here*
https://linustechtips.com/topic/736740-hard-problems-are-hard/#findComment-9349959
Scissor lift as in, like, a SkyJack?
If so, god I hope you've had it certified by an engineer and safety inspector. Using custom built, not certified equipment can get you fined multiple thousands of dollars if caught. Obviously it depends on where you live, but in Ontario, building your own powered lift device can get you in major trouble, for safety reasons.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/736740-hard-problems-are-hard/#findComment-9350210
its not for anything professional. also no one will be on the devise when lifting or lowering. I have designed extra supports to ensure if it does fall it will not fall more than 2 inches. On top of that I have a 4 to 1 safety margin, designed to handle 2 times the max weight (as in the weight that will be on it when stationary) to be lifted and be fine. Also the Mechanical professor and theater director have signed off on it. I have put about 4 weeks of just designing for safety. Here in Alabama there are no laws against it, especially the highest it can go is 5 ft.
https://linustechtips.com/topic/736740-hard-problems-are-hard/#findComment-9350486
Well, if there are no laws against it, I suppose. (That really concerns me about your state Safety Laws though)
If you tried that here in Ontario, they'd nail you to the wall with fines lol
https://linustechtips.com/topic/736740-hard-problems-are-hard/#findComment-9350510
