The First Double Sided Mod Art QUADRAD Custom Case In The World / With Four Loop Four Rad Four Rez
Hello there. Welcome to my new project.
We designed a big extreme case. A case with a square look.
4 radiators, 4 pumps, 4 reservoirs in the system. I wanted to build a system with 4 loops.
For this reason the name QUAD-RAD.
Case design is mine.
This case can be used in different systems.
The case would be made from scratch, not by modifying a standard case.
After our first work, we decided to make a case in this view.
Case Designed as square cross-section and 45 degree broken.
The case is a plain-flap shape with the front and rear top panels on the wings.
It is designed to bend 45 degrees towards the side covers.
With this, the depth of the cradle, normally 18 cm, was removed by 30 cm.
We started making a 1/1 carton to see what the case would be like.
There are air grids on the wings. And on the outside there are reservoirs.
In the form of 4 reservoirs in 4 corners.
https://linustechtips.com/topic/736655-modart-quadrad-custom-case-double-sided/
We made vector drawings of Case.
We used 1.20 mm sheet metal.
After the interrupted spaces, the finished state of the empty stall was 12.5 kg.
Corsair Obsidian Series 900D Super Tower Case is 18.6 kg.....
During vector drawing, we decided to make the box from 4 equal parts, 2 smaller parts equal to the upper and lower, 2 larger parts equal to the front and the back.
The chassis 2 will consist of the top and bottom parts, 2 front and back parts, motherboard back plate.
The radiator grills, specially designed on the 4 sides of the cabin, are integrated with the frame.
In the bottom and top part, another four 20mm diameter holes from the grille will fill the system with liquid from the top.
A)  There are 2 side parts, integrated fangriller and a panel which provides all cable entry and exit into the case in the lower parts coming to the corners.
B)  At the top, a 30 mm diameter ON-OF button and a 22 mm restart button were made. And two USB 3.00 sockets were made.
C)  There are also two 5.25 drawers for fan controllers close to the top.
D)  The HDD control drawer was made near the bottom.
The front and back panels were equally spaced so that both sides of the frame could be used as the front panel.
The drawings were cut in CNC laser.
To check the size of the sockets, the cable box was panned out and the gauge was checked. Necessary corrections were made.
And the CNC sheet is bent with metal bender.
Twisted parts
The cut and bent parts together in bulk.
IMG]http://imageshack.com/a/img924/696/ZbGg6d.jpg[/IMG]
Front and rear panel interior and exterior details.
Details of the upper and lower panels.
I / O Panel is set to face down.
Special extension cables must be used on all sockets to not open the cover each time to mount the mainland cable.
There is no need to open the case cover with extension cables to be attached to the case corners.
Cables collected at the corners.
With the holes to be opened, the cables will be hidden behind the panel.
1- Display Port panel mount cable Male/Female StarTech 3-Feet (6 pcs)
2- USB 3.0 Dual Male/Female Panel Mount Cable 100cm           (6 pcs)
3- HDMI 1.4 19pin Male/Female Panel Mount Extension Cable 60cm(5 pcs)
4- DualPort USB3.0 Female Mount to Motherboard 20pin Cable40cm(2 pcs)
5- MecallTech RJ45 Male/Female Panel Mount Ethernet  60cm     (2 pcs)
6- AC 250V C14 Power Cord Inlet Plug Socket Switch Screw Mount(2 pcs)
7- Ugreen Digital Optical audio cable Toslink gold plate 100cm(2 pcs)
8- Ugreen High Speed Cat 7 RJ45 Ethernet Network Cable 200cm  (2 pcs)
9- Kenable RCA Panel Mount Socket Audio Red White & Yellow set(2 set)
10-Kenable Optical TOSlink Panel Mount Socket to Socket       (2 pcs)
11-Kenable Panel Mount 3.5mm Male/Female Locking Nut Stereo   (6 pcs)
12-Vention Jack 2 RCA Audio Cable to 2 RCA Aux Cable  100cm   (2 pcs)
I'm adding new images right now. I hope the case will be completed in 1 month. :D
Cable routing channels on rear panel opened to provide motherboard connectivity for these cables
The channels on the plate opened with dremel ...
The cables from the corners of the corridors were passed under the SSD and HDDs and were directed to the mainland.
With the installation of PSU + SSD and HDDs, the case back has such an appearance.
  • 1 month later...
The plexi hatches are now in place. The plexi was made from the cover plate.
The plexi cover will be smaller than 1 cm of the foot on the sides of the case.
The corners will twist.
Plexi cover was drawn in corel program. The laser was cut.
These lids will be given a stand image in the space. To achieve this, long thin metal feet between the plexi and the case were considered.
These feet were made in 2 pieces.
When these feet were connected to each other and to the cage, this was achieved at the front and back.
Threaded rods were mounted for easy mounting of the end caps of the bars.
The trial was interrupted by the plexi being interrupted.
Now the ears in the corners are bent. The marked parts on the four corners of the frame will bend.
Bending process.
The parts to bend.
The plexi was fixed by placing an aluminum sheet on the lower part.
The bending part was heated with hot air gun.
And twisted parts.
