PC power issues
Go to solution Solved by MrDrWho13,
9 minutes ago, LinusTechTipsFanFromDarlo said:
A PC shutting off without no warning always indicates a fault with the PSU, I'd get a new one.
Not always. It could easily be the CPU overheating but with the sudden change I'd say it was PSU.
Hey all, So recently my PC has been running into an issue where seemingly randomly, it will just lose power and shut down as if someone unplugged it.
I have not changed any hardware for several months and the problem began just a day or two ago.
PC specs
-Intel core i5 760 2.8ghz
-Biostar t5 xe motherboard
-8gbs of Crucial ballistix sport ddr3
-MSI Gaming X RX480 4gb edition
-EVGA 430 watt power supply
-Adata sp120 boot ssd
-Western digital blue 1tb storage drive
-Windows 10 professional
Any help would be greatly appreciated.
"I take great pride in my humility" -Me
My Steam Profile (from SteamDB)
  • Worth: $1614 ($629 with sales)
  • Games owned: 126
  • Games played: 111 (88%)
  • Hours on record: 3,483.3h
https://linustechtips.com/topic/736524-pc-power-issues/
I would say your PSU is faulty.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/736524-pc-power-issues/#findComment-9348130
I would say that is a definite possibility, but the power supply is relatively new (less than a year old) so I would like to hope that that wasn't the issue.
  • Games owned: 126
https://linustechtips.com/topic/736524-pc-power-issues/#findComment-9348135
زندگی از چراغ
https://linustechtips.com/topic/736524-pc-power-issues/#findComment-9348140
A PC shutting off without no warning always normally indicates a fault with the PSU, I'd get a new one.
FTFY. Very little is absolute when it comes to troubleshooting.
Other systems I've built:
https://linustechtips.com/topic/736524-pc-power-issues/#findComment-9348147
I edit my posts a lot.
https://linustechtips.com/topic/736524-pc-power-issues/#findComment-9348191
I doubt it's the cpu because the cpu and cooler have been regularly dusted and the cooler has been the same for the life of this pc.
  • Games owned: 126
https://linustechtips.com/topic/736524-pc-power-issues/#findComment-9348205
Hey all so I thought I'd update you guys on what ended up happening. So I fixed the problem, which turned out to be a cracked cpu cooler mounting bracket causing overheating whenever the cpu was under any kind of load, I replaced the cpu cooler, but only after having got a new power supply :/ but all is well that ends well.
Thanks for the help!
  • Games owned: 126
https://linustechtips.com/topic/736524-pc-power-issues/#findComment-9377339
