I've already ordered all my parts they should arrive next Friday. While i was waiting i posted my build on forums and got mostly good feedback but, one thing that a lot of people didn't agree with is my PSU. Read up on it and asked around, a couple people said its fine but the occasional reply of "mine died within hours" or "The fan makes a weird noise" over and over has me split.
So these are my options:
Order a different PSU on Monday and it should get here by Friday with all the other parts and just send back the other one for a refund.
Or Just stick with the one i ordered and hope for the best.
I really dont want anything bad to happen when it can be avoided but if the PSU i ordered is actually good or if you have any suggestions let me know
 Build: https://pcpartpicker.com/list/KrLXFd
https://linustechtips.com/topic/736273-suggestions-first-build/
the psu is perfectly fine, they must have confused it with the older CX which was mediocre in quality.
https://linustechtips.com/topic/736273-suggestions-first-build/#findComment-9345706
shouldn't be too bad
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/736273-suggestions-first-build/#findComment-9345710
1 minute ago, Dawson Wehage said:
It's good but if you plan to overclock they are not meant for that, it's the green labels you want to stay away from. If you plan to overclock I recommend a EVGA 650 G2
it's fine for overclocking.
https://linustechtips.com/topic/736273-suggestions-first-build/#findComment-9345717
That's a great build, I don't see anything wrong with it, what I do want to let you know is why did you get a i5? I got a i7 4790k and it was only about $2.5k not only that but I got a 980 ti
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/736273-suggestions-first-build/#findComment-9345727
didnt get the i7 just cause my pc is mostly going to be for gaming and a i7 wouldn't over a lot more in performance at least that what i heard
https://linustechtips.com/topic/736273-suggestions-first-build/#findComment-9345743
Eh, especially in your case (1080p 144Hz), you would have benefitted significantly from an i7 as opposed to an unlocked i5.
The people who say "i7s don't do anything for gaming and should only be used for video editing!" don't know what they're talking about.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/736273-suggestions-first-build/#findComment-9345777
18 minutes ago, Artist said:
So if you were me would you get a different psu will my "tier" of build or keep the one i ordered?
I'd keep it, this cx isn't bad at all.
https://linustechtips.com/topic/736273-suggestions-first-build/#findComment-9345986
