Helo everyone, I am a pc noob and I need some help on my first build. I decide on getting this prebuilt pc http://www.ebay.com/itm/182425989669 and adding a gtx 970 in it, but I dont know if it will fit.  I also dont know if I could remove the motherbard and psu and If I could get a new case instead.
https://linustechtips.com/topic/736241-does-it-fit/
It wont fit due to the fact its a slimline case, as for taking out the motherboard and psu, most motherboards in dells, hp's etc... are custom for the machine and may not fit on standard motherboard stand offs
https://linustechtips.com/topic/736241-does-it-fit/#findComment-9345360
No it won't. That case isn't meant for add-on cards.
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/736241-does-it-fit/#findComment-9345361
