Some of them (Apparently) have better flow, and they let you change the barb/fitting sizes.
This, it also sometimes gives you more/better locations for fittings, as well as looking better.
Intel 3570k @ 4.4 GHz |Asus Sabertooth Z77 |EVGA GTX 660 Ti FTW |Kingston HyperX Beast 16 Gb DDR3 1866 (2x8Gb)
|Samsung 840 250 GB |Western Digital Green 2TB 2x |Cooler Master 850w 80+ Gold |Custom Water Cooling Loop |Noctua NF-F12 4x
|Noctua NF-A14 3x |Corsair Carbide 500R (White) |Corsair K95 |Razer Mamba |Razer Megalodon |Samsung SyncMaster T220 2x Computer Bucket List   Greatest Thread Ever   WAN Show Drinking Game  GPU Buyers Guide
https://linustechtips.com/topic/73599-what-does-a-pump-top-do/#findComment-1008382
Yeah, pretty much what others have said. Some provide better flow and give better variety of options for fittings. They also make your pump look better! Stock top on D5 looks like poop!
Build log
CPU: FX-6100 @ 3.9 MOBO: GA 990XA-UD3 RAM: Corsair Vengeance 8GB GPU: HD6870 PSU: Corsair GS800 Case: Bitfenix Outlaw SSD: Samsung 840 250GB HDD: Seagate Barracuda 1TB Cooling: Custom Water-Cooling Peripherals: Keyboard: G710+ Mouse: Steelseries Sensei Steering Wheel: Logitech G27 Sound: Speakers: Logitech x530 Headset: Razer Chimaera Monitor: Benq G2450HM, LG 32" TV
https://linustechtips.com/topic/73599-what-does-a-pump-top-do/#findComment-1008464
Also, some tops have the reservoir built onto them, so you can have an easy option for mounting the reservoir.
Desktop - 3930k | Rampage IV Extreme | 64gb Vengeance RAM | 256gb 840 Pro | 2x MSI 7870 | Corsair 900D | Creative SB Z | Sennheiser HD280 | Logitech G710+ | Razer Mamba | My salary's worth of water cooling.
Server/NAS - i5-4570 | Gigabyte Z97 Ud5h | 32gb Crucial 1600mhz | 500gb Samsung 850 evo | 4x 4tb WD Reds | Corsair H80 | Bitfenix Shinobi | Windows 7 Pro |
https://linustechtips.com/topic/73599-what-does-a-pump-top-do/#findComment-1012605
Do you guys know what the heck the rings to secure tubing to barbs are called? For the life of me I can't remember the name and I need to get some
Barbs or compression fittings? If barbs, do you mean zip ties?
https://linustechtips.com/topic/73599-what-does-a-pump-top-do/#findComment-1013059
for barbs, and yes like zip ties but the metal ones that you tighten with a screw driver
Hose clamp. http://lghttp.17653.nexcesscdn.net/808B16/cdn_images/media/catalog/product/cache/1/thumbnail/9df78eab33525d08d6e5fb8d27136e95/i/r/irc607a.jpg
hardware store, amazon, autoparts store.
https://linustechtips.com/topic/73599-what-does-a-pump-top-do/#findComment-1013205
thank you! i couldnt remember "hose clamp" i tried hose tie, tube tie, tube clip. i dont know why it was escaping me
Tohrchur
https://linustechtips.com/topic/73599-what-does-a-pump-top-do/#findComment-1013233
