Hey people,
So I just started using surround mode and have it set up with three monitors, everything is fine except for when I disable surround with the default CTR+ALT+S when I do this the main monitor still works but the ones on either side just go blank, I then have to enable them again via windows display settings. This is so annoying doing it all day, I must be doing something wrong? surely Nvidia don't think this is a smooth experiance.
What should I be doing?
Thank you
Azure Fists - "Grown men playing with each other since 2009"
CPU : Intel® Core™ i5-4590T, OS : Windows 10 64bit + Custom Alienware Console Interface, GPU : NVIDIA® GeForce® GTX 860M 2GB GDDR5, RAM : 8GB Dual Channel DDR3L 1600MHz, SSD : Kingston V300 240GB, WIFI : Intel® Dual Band Wireless-AC 7265 2x2 + Bluetooth 4.0, CASE : Alienware Alpha, PSU : External Power Brick, MOBO : Custom Dell Motherboard.
CPU : i5 6600, Mobo : Asus Z97i-Plus, RAM : 16GB DDR4 3000mhz Corsair Vengeance LED, GPU : Gigabyte G1 GTX 1080, Case : Silverstone RVZ02, Storage : SanDisk 1TB M.2, PSU : Silverstone Strider SST-SX700-LG, Display(s) : AOC Q2963PM 29" IPS Ultra Wide 21:9, Fans : Noctua NH-L9i with Be Quiet Pure Wings 2, Keyboard : Razer Blackwidow Stealth 2015, Mouse : Razer Naga 2015, Sound : LG Wireless Soundbar /Razer Kraken Pro, OS : Windows 10
https://linustechtips.com/topic/735684-nvidia-control-panel-surround-mode/
NVIDIA Surround is crap, they dont ever bother to fix anything with it. i have 3 screens and it took me less then a day to realize i would never want to touch it ever again. cant run anything but 60Hz, no snapping, shit FPS because 970 lol, and the problem you just described. i hate it and i just run it as 3 separate screens instead, works better for 99.9% of the things i do
Builds:
So how would you turn them into one big display for gaming?
i dont bother. its nicer to play at good FPS on a 77Hz display then at 60fps medium settings on a huge as 60Hz display. if i wanted to use it as one big display id either use the shtty surround or i would put the game in windowed mode and stretch it across all 3 screens if it allows for that(Minecraft for one allows it). lots of games UI gets super messed up at 5760x1080(CS:GO is a good example of that) and quite a few just refuse to run at 5760x1080 and only displays on one screen anyway.
Builds:
I play fps on one screen but I enjoy rpg games on triple monitor set up. But I did lots more research and looks like I'll just have to put up with rubbish nvidia control panel like everyone else.
