I'm between the K70 LUX RGB with Cherry MX Browns and the Razer Blackwidow Chroma v2. I wanted mx blues but i can't find a k70 lux RGB with mx blues. I have no experience with Razer products, I've always thought they were overpriced and quality was not on par with Corsair's, but i might be wrong. What do you think?
https://linustechtips.com/topic/735305-help-me-choose/
the k70 is a better built keyboard but if u want something similar to mx blues then i would go for the razor with green switches
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/735305-help-me-choose/#findComment-9335133
Master keys Pro M all day man
Compact without sacrificing the number pad, I'd go with Reds though, Think theres an MX blue option, but are you sure the click isn't going to bother you?
https://www.amazon.com/MasterKeys-Mechanical-Keyboard-Intelligent-Switches/dp/B01ITE93K6
Although the Pro L does have an RGB variant, it's only $120 as well *It does indeed have at least some RGB functionality without software, which is really nice to have
https://www.amazon.com/MasterKeys-Mechanical-Keyboard-Intelligent-Switches/dp/B01D3BDNF6/ref=sr_1_2?ie=UTF8&qid=1486606168&sr=8-2&keywords=MasterKeys+Pro+L
https://linustechtips.com/topic/735305-help-me-choose/#findComment-9335406
