Hi all!
I'm having a problem with my Corsair Strafe mechanical keyboard:
it is no more recognized by the system:
                      it is on, red leds are animated (with an animation which i didn't choose) and my usb headphones, connected on the back USB of the keyboard, are still working, when i try to type something, the keyboard does not work (even                         Caps-Lock or Block-Num are not working).
                                  _ I detatched the keyboard;
                                  _ on "device manager" i tried to uninstall the 4 voices "keyboard HID",
                                  _ then i uninstalled the updated CUE,
                                  _ update MB chipset and drivers,
                     reinstalled everything but never hearing the magic "Too-doo!" when connecting the keyboard.
Now i'm using an usb keyboard and, on the BIOS, i saw that there are 2 keyboards connected but just one of the USBs where my Strafe is connected is used by headphones.
I don't know what to do T.T
Pls help me if u can.... <3
Thank you
P.S.
MB: MSI z97 gaming 5
CPU: intel i5 4690k
OS: Windows 10 x64
p.p.s.
forgive my very bad english :(
Edited by dotNetSam
https://linustechtips.com/topic/735242-corsair-strafe-issue/
do you have another computer to test it on?
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/735242-corsair-strafe-issue/#findComment-9334503
Well... just inform who should find this post looking for a solution for the same problem:
 i found on the device manager that "another installation is required" for the Strafe, so i tried to know more and on it's events details i saw that ther was a problem with the migration of the device and with administrator permissions,then i tried some random stuff on cmd but in the end..........  i called Amazon to replace the product, just not to even risk to void the warranty
Sry guys. :(
BTW i'm still curious, so if someone founds a solution i'd be glad to know it anyway.
Best regards to everyone!
https://linustechtips.com/topic/735242-corsair-strafe-issue/#findComment-9347835
