GTX 1070 FE HIGH TEMPS!!
Solved by Emberstone,
Because Nvidia's default fan curve on the Founders cards is awful (they won't let the fans go past 50% and instead throttle the card at 82 C), you need to download something like MSI Afterburner and make a steeper fan curve.
I have a 1070 FE at stock and it never goes above 65 C since I tweaked the fan.
VixAAT ·
AlfaProto ·
Posted in Troubleshooting1 -
busby_bee_boy ·
1
Edward78 ·
Posted in Linux, macOS and Everything Not-Windows1 -
4
Plouffe ·
Posted in LTT Releases2
