It's not underclocking, it's underVOLTING. Undervolting it the act of using the mobo BIOS to reduce the amount of power the CPU needs, without doing it enough to reduce preformance, to make the system consume less power. This can be done beacause the manufacturer of the CPU usually lets the CPU more power than its needs, to allow headroom.
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
That's not right at all. unlocking is both unlocking and undervolting.
anything that runs too hot or runs on batteries benefit from underclocking along with undervolting.
But you can reduce the voltage without reducing the clock speed. It is true. I read it in a MAXIMUMPC magazine, which I think is a reliable source. But, you can also reduce clock speed, but this practice is not commonly done on desktops.
42
also,
My build:
I remember underclocking a desktop CPU once for stability reasons.
My dad's old Athlon 1.4 GHz, back in early 2008, had gotten to where it would shut down after only a few minutes or so of use, making it almost unusable.  (I forget if it would BSOD, or just power off.)
I underclocked it to 1 GHz in BIOS (900 MHz wouldn't boot), and was able to use it for about 20-30 minutes at a time.  Between a few sessions, this was sufficient to allow me to order the parts for my own first PC, which included an Athlon 64 X2 4000+.  (I wish I could have gotten something like a Q6600, but I was on a <$500 budget.)
57 minutes ago, basedthirst said:
Why might one underclock a CPU, wouldn't it just run slower?
You generally wouldn't, unless maybe you were trying to squeeze a little bit more life out of a slowly dying CPU.
Most modern CPUs will clock themselves up and down depending on what kind of work they're being asked to do to be more efficient and to let the fans quiet down when possible (assuming you didn't turn that off), but that's just basic functionality.
