So I'm a 3rd Year Mechanical Engineering Student. My Heat Transfer Professor asked us to write our own problem for homework. Seeing as though I liked computers, here's my submission. Note that all the material properties are completely made up. Enjoy! Post your answer if you're actually capable!
Intel’s flagship i7-6950X processor has a TDP of 140 W. After purchasing this $1750 processor Adam can only afford a small heat sink and has no money left over for thermal compound. Adam researches online to find that toothpaste can work as a substitute thermal compound as it has a thermal resistivity of only R=.25 K/W. Wanting to be better safe than sorry, Adam finds a cheap thermal paste online that claims a thermal resistivity of R=.2 K/W. Adam scours product pages to find that his heat sink has 40 different fins that are 45 cm^2 and is capable of a convection coefficient of h=60 W/m^2K. He then determines through the BIOS and sensors on his motherboard that the ambient temperature of his case is Tinf= 38'C . If Intel advises maintaining your CPU below 85'C and most people like to stay below 80'C for safety, is the thermal compound a worthwhile purchase? Ignore Radiation and conduction through the heat sink.
BTW don't missinterpret this as I don't know the answer at all. I made the problem based on answers I created beforehand, I want to see if you've got the guts.
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/735087-solve-this-problem-i-made/
Whether or not the cooling system is capable of keeping the processor within temperature is entirely up to how much load you're putting on it. And if we assume power consumption = TDP.
A system would theoretically only fail if pushed to its limit
Don't you need to know the thermal conductivity and not the thermal resistance? Also you would need to know the thickness of the interface material between your heat source and your heat sink. I may be wrong though
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
You're absolutely right. You would need a lot more information to get a real and precise answer. This is just a more simplified approach.
And I used thermal resistance to make it an easy equivalent circuit problem
the headtsink comes with thermal paste? most do
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
Well this one was so cheap that it didn't.
I just love how everyone is trying to pick apart your problem like they have never taken a physics class :P Nobody is actually trying to solve it or to comment on the phenomenon :D
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
I took a physics class I just didn't learn this in it.
Neither did I, but at some point in basic thermodynamics I got curious and investigated into heat propagation and dissipation. I still remember some basic stuff
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
What a cool problem!  I have completely forgotten all of this stuff.  What equations should I be looking for?  Conceptually, the rate of heat transfer depends on the steady state temperature gradient across the system.  I'm pretty sure this involves a bit of calculus to solve.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
I just took a basic physics class in HS. I don't think we got to thermal dynamics. If OP provided an equation to use I would have been able to try but I am not an engineering/physics student so I have no idea how to solve this.
Finally someone who has some idea. It's set up so that you have two resistors in series. The first resistor is the different thermal solutions, the second is the convection from the heat sink, represented by the equation 1/hA where A is the total surface area of the radiator. Combine to make an equivalemt resistance, and solve using the equation q=(delta T) / (Req). Simple enough,
I see your point in not having equations provided. Unfortunately it's a nothing from high school, but rather a 400 level college course, so our professor expects us to have all relevant equations memorized. Certainly not common knowledge.
Yeah that's what I figured. This stuff is really complex; at least for me.
Well if there's less resistance,  there's more conductivity,  is there not?
Corsair 4000D RGB
Asus B550 Tuf Gaming II
Asus 7700XT Tuf Gaming
AMD 5600x3d
32gb 3200mhz gskil
correct
