Can anyone help with excel the cell block I want certain cell block smaller, but not all the cell block smaller. What I am trying to do is make cell beneath  "Learning about words" smaller so that I can make it fit into a page and make the text bigger when it is printed out. I try it extracting to word and it just more of a hassle to deal with the cell problem. Does anyone know how to fix this problem?
I want a fully fledged no white spot beside the top right side.
Conversion Table.xlsx
https://linustechtips.com/topic/734688-excel-help/
English??? Very hard to decipher what you mean...
Also the cell beneath "Learn about words" is empty. Resizing it will do little to change anything.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/734688-excel-help/#findComment-9327915
Not quite sure what you want to do. Could you elaborate? Perhaps include diagrams or images that better illustrate your intents?
Cheers!
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/734688-excel-help/#findComment-9327921
